New Timing Belt
Old Oct 8, 2009 | 08:36 AM
Outlaw-Hondaz's Avatar
Default New Timing Belt
I just replaced my timing belt on my h22a4. now that it is in, everytime the motor starts you would hear a noise coming from the timing belt section. I think it could be the tension rod. And everytime you gas the car the sqeaking noise would get louder. What else could it be? HELP!!
Old Oct 8, 2009 | 08:39 AM
Simkin314's Avatar
Default Re: New Timing Belt
I don't have an H22 but I would definitely check the tension...did you replace the water pump at the same time?
Old Oct 8, 2009 | 08:40 AM
mafia's Avatar
Sounds like a loose belt (not the timing belt)
Old Oct 8, 2009 | 08:44 AM
Simkin314's Avatar
I change my answer... didn't think of that
Old Oct 9, 2009 | 02:34 PM
no...should i do it and see if the noise is still happening??
Old Oct 9, 2009 | 02:40 PM
Enzo15's Avatar
check your accessory belts, My alt belt was real loose, and would sqweel like no tommorow lol. Took out the A/c and got a shorter belt.. All fixed now :D
Simkin314's Avatar
Yes, check the tension / tighten all the accessory belts (i.e. power steering, alternator, air conditioning))
Old Oct 9, 2009 | 05:31 PM
R666_EK's Avatar
Did you do a manual tensioner conversion? If its not the accessory belts, which it very likely is. Manual tensioners can squeal when going out.
Osis
Honda Civic (2001 - 2005)
Oct 15, 2007 08:23 AM
BOOSTEDgreeneg
May 25, 2005 12:51 AM
obd2gsr
Dec 21, 2002 08:53 PM
$300lude
Dec 15, 2002 09:25 PM
nerdish
Jul 17, 2001 11:22 PM
