Honda S2000 Honda S2000
How do you check a CEL on an s2000?
Old Oct 8, 2009 | 02:50 AM
Tuner Eddy's Avatar
Default How do you check a CEL on an s2000?
Hey guys,
I was on my way to work this morning and my check engine light came on. The car still runs perfect, nothing happened when the light came on.
I've only been an s2000 owner for 3 weeks, so I'm not sure if there is a way to check a CEL other than an OBD2 scanner?
I'm coming from civics, where all I had to do was ground out the jumper plug under the dash.
Thanks in advance.
--Ryan
Old Oct 8, 2009 | 03:31 AM
HondaKyle's Avatar
Default Re: How do you check a CEL on an s2000?
autozone will check for free...
Old Oct 8, 2009 | 04:41 AM
Redgts's Avatar
Buy a scanner you can get them for 80-100 bucks now, write down the code or codes and check them on a website. Good thing about having your own scanner is that you can clear the codes.
Old Oct 8, 2009 | 04:43 AM
HondaKyle's Avatar
autozone clears them...
Old Oct 8, 2009 | 08:55 AM
Tuner Eddy's Avatar
Thanks Kyle. I didn't know if they still did it or not. I went to autozone on my lunch break, it was the gas cap code. I opened the gas door and the gas cap was loose......doh.
Autozone then cleared the code, thanks!
Old Oct 8, 2009 | 10:40 AM
White Smoke's Avatar
i my honda
Global Mod
Check your codes: https://honda-tech.com/forums/showpo...0&postcount=10
Autozone is not allowed to clear the codes by law, at least here in MD.
Old Oct 8, 2009 | 12:13 PM
k!ng's Avatar
white smoke is correct
you, the owner, can clear it though
p.s. it's not a good idea just to clear the ****. fix the problem, then clear it. the CEL will come back anyway if you just clear it.
Old Oct 8, 2009 | 01:16 PM
Tuner Eddy's Avatar
they can clear it here in Alabama. We don't have vehicle emissions/inspections.
No ****, did you read the part where we figured out what it was and how I fixed it?
Old Oct 10, 2009 | 11:42 AM
k!ng's Avatar
yes, i saw the part that talked about how you're a dumb **** who doesn't know how to tighten a gas cap. complicated **** for someone who calls himself a tuner, douchebag.
as an fyi, what i said was a general rule of thumb for anyone who may see this thread.
get over yourself.
Old Oct 10, 2009 | 12:48 PM
esean93's Avatar
Hahahaha u can't tighten a gas cap,clear cels and u have a attitude!wow!
maddcrx
Honda S2000
10
Sep 15, 2008 06:11 PM
honda11111
Mar 29, 2007 03:51 PM
jeux
Jul 10, 2004 08:40 PM
sagaprelude
Honda S2000
Aug 4, 2003 10:03 PM
S13 slide
Oct 8, 2002 01:23 PM
