Mystery Hose
Old Oct 7, 2009 | 10:16 PM
flabby's Avatar
New User
Default Mystery Hose
I have a 1999 Honda Civic with a hose that is not connected to anything. The hose is boxed in red.
Here's a close up.
I think this (the red arrow at the bottom) is where the hose originates.
I believe it has to do with the air conditioner. It's been weak. I'd like to know what the hose connects to and where it should be connected.
Old Oct 7, 2009 | 10:25 PM
Sic_DA_Nine's Avatar
Default Re: Mystery Hose
in for a answer
i think mine is disconnected to....as i remember seeing that in my engine bay.
ill have too look at it tomrrow
Old Oct 8, 2009 | 12:22 AM
uwishucould158's Avatar
i think its for some carbon filter crap its soposed to be like that it ges to a charcoal canister i think i dont know what its for in my hatch i pulled all tha **** out didnt see any difference i also got it now in my coupe
Old Oct 8, 2009 | 12:24 AM
onsetofpurity's Avatar
Pull it really hard maybe it will come out. LMAO
Old Oct 8, 2009 | 12:27 AM
Reppiks's Avatar
It connects under your battery tray to drain water, or acid away from electrical connections
Old Oct 8, 2009 | 05:17 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Either that, or it's the drain for the A/C evaporator behind the firewall... same general location. In fact, I kind of think that's what it is. It's why Hondas always have a wet spot under them right there when the AC is running. If it clogs up or gets kinked, you'll get water on the passenger footwell when the AC is running.
Old Oct 8, 2009 | 05:46 AM
Former User's Avatar
Where you see the hose is where it belongs. It's part of the EVAP system. What has happened is that the drain joint, which secures the hose to firewall, has broken. It's part #16 in the diagram.
Old Oct 9, 2009 | 04:55 AM
flabby's Avatar
New User
Thanks for the responses.
So is the drain joint suppose to be connect to that screw directly above the open ended hose?
Old Oct 9, 2009 | 05:41 AM
Yes
Old Oct 9, 2009 | 08:43 AM
roycivic92's Avatar
i thought it was like a drain for the wipers
Old Oct 9, 2009 | 10:07 AM
honestly i dont think there is a need to fix it cause it dosent go into the fire wall where the screw is if somthing were attached which it looks like there was but it would still just sit there
Old Oct 9, 2009 | 11:10 AM
This is another viable option.
Old Oct 9, 2009 | 01:47 PM
Dkober101's Avatar
had that prob before, but i dont think thats it.
Old Oct 9, 2009 | 04:36 PM
gwl's Avatar
gwl
I have two Civics and there both hooked up to the fuel filter. It doesn't drain anything, it just holds up a hose line that almost runs parallel to the firewall.
Old Oct 9, 2009 | 05:04 PM
would this cause any codes to go off??
mine is the same way..and i have a evap leave cel
Old Oct 9, 2009 | 08:10 PM
PhatFactory's Avatar
correctdomodo my brotha. You rock!!
Old Oct 9, 2009 | 08:19 PM
gwl's Avatar
gwl
Well, what I meant, it just hang off the fuel filter assembly. There is a square notch on the filter assembly and at the end of hose has a square shaped plastic end. It just hangs there. Odd. and no CEL
HndaOwner
Mar 8, 2016 04:14 PM
Rob.
Jun 21, 2009 11:15 AM
RicharDC4
May 27, 2009 05:45 PM
Rob.
Mar 27, 2009 11:00 AM
gursh d
Aug 21, 2007 08:35 AM
