Oil feed line for turbo...on Dohc zc.
Old Oct 7, 2009 | 04:59 PM
bchap's Avatar
Default Oil feed line for turbo...on Dohc zc.
I'm trying to run my oil feed line, and can't seem to get the oil pressure sender off the back of the block, it is to close to the oil filter mount to get a socket on... Anyone done this before? Tips?
Old Oct 7, 2009 | 06:55 PM
dephtone's Avatar
Default Re: Oil feed line for turbo...on Dohc zc.
Run a T fitting off the back of the block, since it has 3 ports, plug one of them off, get a NPT to whatever fitting on the oil feed line and then just hook up the oil pressure sender (one prong sensor you probably took out).
This will allow you room to screw in the T fitting as well as your oil feed and pressure sensor.
Like so:
96ej8MR
Sep 11, 2007 01:46 PM
planoguy36
Apr 9, 2006 08:09 PM
tissimo
Apr 6, 2005 12:46 PM
zbower7
May 14, 2004 01:42 PM
turbotec
Feb 26, 2002 12:36 PM
