MPFI Swap code 4 problem
Old Oct 7, 2009 | 04:43 PM
rebelwolf18's Avatar
New User
Default MPFI Swap code 4 problem
I have just put a d16 head non-vtec on a d15 block, added mpfi to the car, i have done all the necesary wiring and mods that i needed to. I went to start and got a code 4 from the si distributor. I know this is a noob question but i am at my wits end, what is the best course of action to do from here? I have all the grounds and wiring conections done.
Old Oct 7, 2009 | 04:59 PM
424racer's Avatar
Default Re: MPFI Swap code 4 problem
check the 2 wires that you added to the dizzy, see if you put them on backwards.
if not and your wiring is right - change the dizzy...
Old Oct 8, 2009 | 02:25 AM
BiGZ's Avatar
^ x2,and VERY common mistake to have them bassackwards due to different writeups online... (some view back of ecu plugz,some the front making wiring well-backwards) Try de-pinning @ dizzy and swap them (or @ ecu if easier for ya) Hope that made sense
Old Oct 8, 2009 | 08:14 AM
rustbucketrex's Avatar
Check wiring connections, if they're not tight, the ECU will notice the difference in voltage and give you a code. Don't buy parts that you do not need.
Old Oct 8, 2009 | 08:56 AM
New User
i have added four wires total to the ecu harness which pins do i need to try and switch, larger pins and smaller pins.
DA9Sleeper
Nov 6, 2011 06:57 AM
Rick777
Feb 5, 2010 12:56 PM
89s1
Aug 23, 2009 05:10 PM
143MYVTECEF
23
Oct 16, 2006 09:54 PM
ludelvr
Mar 13, 2005 05:57 PM
