clicking noise on morning start up only
Old Oct 7, 2009 | 03:20 PM
roycivic92's Avatar
Default clicking noise on morning start up only
hey fellas i get a clicking noise from the head only in the morning for about 10 second then it goes away , u think it needs a valve adjustment.?
Old Oct 8, 2009 | 07:41 PM
roycivic92's Avatar
Default Re: clicking noise on morning start up only
bump
Old Oct 8, 2009 | 07:47 PM
mortificationrock's Avatar
In for reply..my **** does the same.
Old Oct 8, 2009 | 08:38 PM
r33dm0n3y's Avatar
my car does this too. i am pretty sure it needs a valve adjustment...just haven't had time to take mine in.
Old Oct 8, 2009 | 08:43 PM
KevinBrown's Avatar
Tapping, ticking sound? If so, then yes you most likely need an adjustment.
Old Oct 8, 2009 | 08:50 PM
Former User's Avatar
Is the your engine oil low? What type of oil and oil filter are you using?
Old Oct 8, 2009 | 11:59 PM
roycivic92's Avatar
good on oil and using 10/40 castrol in a b20b
Old Oct 9, 2009 | 08:13 AM
mn99si's Avatar
Definetely could be your valves....all Honda's I have seen will make a slight ticking noise at cold start-up wait about 2 minutes to warm up and it should go away start with a valve lash adjustment.
Old Oct 9, 2009 | 08:26 AM
roycivic92's Avatar
adjusting the valves today.
Old Oct 9, 2009 | 11:57 AM
itsnotfast's Avatar
Keep in mind though that when you first start the car in the morning all of the oil has drained into the oil pan. It will take a few seconds for the oil pump the circulate oil back into the head. Valve adjustment wouldn't hurt though.
Old Oct 9, 2009 | 01:41 PM
roycivic92's Avatar
yeah but i think is worse than normal and a adjustment wont hurt
Old Oct 9, 2009 | 06:16 PM
itsnotfast's Avatar
Does the car have high miles on it?
tercelrcr
Apr 30, 2011 09:08 PM
lke2drvgsr
Jul 13, 2010 04:46 PM
redline870
13
Apr 13, 2009 06:03 AM
do what
11
Oct 25, 2005 12:34 PM
