Someone Help Me With This...
Old Oct 7, 2009 | 02:23 PM
NAturalEk9's Avatar
Default Someone Help Me With This...
Earlier i was driving today and while i was at a stop sign i was about to go and all of a sudden the car wont engauge anymore like it just sits there and revs up i cant reverse or nothing i know my tranny isnt out cause i can still move it into gears and the clutch still feels fine what could it be?
Old Oct 7, 2009 | 04:47 PM
rebelwolf18's Avatar
New User
Default Re: Someone Help Me With This...
Check your clutch cable...it may have went out of adjustment
Old Oct 7, 2009 | 07:18 PM
NAturalEk9's Avatar
hmm it might be my throw out bearing also cause i was going to test it to see if it would move and i accidently forgot it was in 1st so i let off the clutch and the engine was still on?? it was weird
Old Oct 8, 2009 | 03:35 AM
BryanM.'s Avatar
Resident Gearhead
Any chance one of the axles poped out of the diff?
Probably not. Not to mention, going by his user name, doubtful his car has a cable clutch tranny.
Old Oct 8, 2009 | 09:30 AM
NAturalEk9's Avatar
thats what i thought too so i changed my axle to a new one i had laying around ill have to take out my transmission to see then
Old Oct 8, 2009 | 09:31 AM
NAturalEk9's Avatar
my transmission is a GSR hydro tranny
Old Oct 8, 2009 | 09:47 AM
Simkin314's Avatar
You can shift into gear just fine, release the clutch, and you just don't move...you just rev up?
I am leaning toward the clutch system. Check along the entire clutch line, from pedal (inside vehicle side of master cylinder) to clutch slave cylinder (clutch slave cylinder output rod). Past that...
"hmm it might be my throw out bearing also cause i was going to test it to see if it would move and i accidently forgot it was in 1st so i let off the clutch and the engine was still on?? it was weird"
Old Oct 8, 2009 | 09:49 AM
mouab18c1's Avatar
was there ever any problems before this? did it make any weird noise?
Old Oct 12, 2009 | 09:11 PM
NAturalEk9's Avatar
nope no weird noises but im taking the tranny out tomorrow so i should figure it out
89gsrcrx
Jun 30, 2012 02:57 PM
hiphop23j
Apr 19, 2008 09:41 PM
Wannarace62188
Jun 12, 2006 07:17 AM
Universe95gsr
Feb 6, 2004 06:30 AM
locass316
May 13, 2003 08:53 AM
