Want to Swap a b16 in my EK
Okay So i want to swap a b16 in my stock 1998 EK hatch. My friend has a b16head and Bottom block, but no head-studs to put them together, I just want to gather all the parts I need to do this swap and Im wondering how much it would cost?
Things I know i need
Headgasket
headstuds
Would i need
axles?
Motor Mounts/ tranny mounts?
any wiring harness?
any other parts I would need? and cost?
thanks for reading. any help feedback, tips would be great.
Headgasket
headstuds
Would i need
axles?
any wiring harness?
Headgasket
headstuds
Would i need
axles?
any wiring harness?
Headgasket
headstuds
Would i need
axles?
any wiring harness?
local swap means find someone on craigslist whos selling a swap, i didnt realize how complicated that sounded. and dont forget the price of a b-series tranny. sure you could get an ls tranny cheap but that doesnt keep the b16 in its power band worth a ****. and an si or gsr tranny wont be too cheap, unless you get lucky. ive seen ppl sellin si swaps as low as a grand, which wouldnt be too hard to spend on a good tranny, wire harness, ecu, head bolts, gaskets, axles, etc.
you'll need a b16 reat t bracket,re-use ur oem tranny mount,b16 driver side bracket with two wide holes or integra DA obd-o with oem regular water cup mount.use an ex harness make sure it's obd-2a. find b16 head studs and b16 head gakset.and u shoould b good,use any b series axle xcept for DA. if u use DA axles u will have to change the half shaft too.
project91crxsi
Sep 26, 2011 12:00 PM
ek82
Dec 11, 2005 01:27 PM
TRDSUPRAT88
16
Jun 16, 2004 08:11 PM
