Accord Type-R Turbo build thread 56k 3x BEWARE
Old Oct 7, 2009 | 12:08 PM
funnyboy's Avatar
Default Accord Type-R Turbo build thread 56k 3x BEWARE
Hi guys,
Decided to share some info with you. Building this car for 2.5 years, had already one setup that had mahle gold's that broke, they aint no good. Trust me.
So now there is the new setup. Pictures starting from newest.
Whats more please give some advice, i have unknown engine clicking noise at very low rpms. One you throttle it even 2$ noise dissapears.
There is some video.
http://www.youtube.com/watch?v=uSsaJ405Utc
Build thread in next post
Old Oct 7, 2009 | 12:13 PM
funnyboy's Avatar
Default Re: Accord Type-R Turbo build thread
Enjoj. If anyone ask im from Europe-Latvia
Old Oct 7, 2009 | 12:39 PM
Sales@Bisimoto.com's Avatar
Default Re: Accord Type-R Turbo build thread 56k 3x BEWARE
WOW that's some crazy work there.
I'm interested to see how this performs
Old Oct 7, 2009 | 01:06 PM
LogicMotorsports.com's Avatar
Originally Posted by funnyboy
Hi guys,
Impressive build! I really like the Euro R... As for the noise? It sounds like it's coming from the bottom end. I would go through it once more. Before any possible catastrophic failure. GL and keep us posted.
Brad_and_the_acc's Avatar
OMG
CRAZY BUILD...
I see LOTS of pics and I thank you for that but please list specs..
>EDIT: GANGSTER MANIFOLD BTW..
Old Oct 7, 2009 | 01:10 PM
H22PwrdInspire's Avatar
I'm diggin the turbo manifold. That is a wicked setup. I would love to see what kind of power numbers you put down on this setup.
Old Oct 7, 2009 | 01:11 PM
whitewonder's Avatar
Very nice build... you got some pretty good fab skills and clean.
does the sound go away if you press the clutch ?
or maybe valves ?
Old Oct 7, 2009 | 01:13 PM
TRA_Blaze's Avatar
wow....woww twice once for an actual EuroR and the second one for all that hard dedicated work put into that CL1 nice job man!!!
Old Oct 7, 2009 | 01:17 PM
GhostAccord's Avatar
F#@k'n Sweet Build! Nice manifold fabrication. The pictures say it all
Not 100% on the noise......maybe a valve out of adjustment?
Old Oct 7, 2009 | 03:31 PM
LSR 0NE's Avatar
JUst wow!
Old Oct 7, 2009 | 07:22 PM
kd97accord's Avatar
I......love......that.......header............That is eye candy. Such a mess of tubes, its a work of art!!
Old Oct 7, 2009 | 07:44 PM
GlassJAw's Avatar
Nice Type R Accord you got there mate, love the subtle differences between the Type R Accord and the Euro R's.
I was wanting to Turbo my Euro R as I see lots of people putting Turbo's onto Type R engines with great success. You sir give me more fuel for my lust for boost!
Old Oct 7, 2009 | 10:40 PM
funnyboy's Avatar
With GT35 it will probabbly be some 500 WHP with good torque and 600whp with low torque.
Bsides EuroR and Type-R are two differend cars, on two different chasis. EuroR is CL7 and Type-R is CH1.
Accord Type-R was produced in Europe in United Kingdom as a limited edition of 2000 cars each years, for Honda to be able to participate in WTCC competition. Type-R has H22A7 engine, sport chasis that is completelly different to other accords. And some other changes.
After UK made Type-R, Japan unsderstood that Europe has cheated from them Type-R model and said that Type-R's are japanese models. So they got angry and as an answer made EuroR that is for Japanese market bus is more or less standart Accord with H22A8 engine that in not half/hand crafted as H22A7. Type-R also got specific engine management on OBD-2A that had some serious tuning over any other H22 engine in the market. Although H22A7 has always had 212HP it has always performed a lot better than any H22A8 or H22A that claims to had even 220HP.
From what i know they made only 6000 Type-R's, as for 2000 units each year. All where built in United Kingdom.
EuroR
Type-R
Old Oct 8, 2009 | 11:55 AM
GlassJAw's Avatar
Not to take anything away from you or try to sound snarky / pissy funnyboy but.....
The Euro R has a seriously tuned / specific ECU for the car - OBD2B. Reason for this being the engine has larger cams, a ported head with a single runner intake (like the H22A7).
Also it is far from being a "standard" Accord with a H22A8 engine slapped into it, the suspension is uprated, has larger 300mm 5 lug brakes, close ratio box fitted with Hellical LSD standard, Recaro interior (as with the Accord Type R) full spoiler kit and a twin exit exhaust amoung other things.
Its downfall is that its based on a more narrow / shorter wheel base due to taxation laws in Japan giving it less track and possibly less handling ability compared to the Type R Accord.
Either way both cars are an engineering feat and both adorn the great "H" badge so they must be good right?
Top work on the Turbo Manifold BTW loving the placement of the turbo.
Old Oct 8, 2009 | 12:28 PM
funnyboy's Avatar
Ok, i went too hard on this.
Still Type-R main advantage is that it has different chasis not just lowered like EuroR, Theoretically Type-R chasis was used in WTCC, but i believe in modified form.
Still i like Type-R look way more than EuroR. But it depends on individual.
Old Oct 8, 2009 | 01:48 PM
GlassJAw's Avatar
Questions I have for you funnyboy, was the original damage (piston / liner scouring) done to the engine in N/A form??
Did the cambelt snap cause any damage to the engine??
Either way I love all the work you've put into it, it must pull like a school boy thats recently discovered he has summin in his pants!!
My individual taste is towards the Euro R's looks over the Type R..... but I'm biased as I have a Euro R (to me the Type R looks like a JDM Raf aga) Type R has too much ground clearance from Factory. The white car pictured above is just a standard Accord with a Euro R Grille / Bumper on it, Euro R's have Fender Flares & lightweight Magnesium 16" rims as well.
Also the Euro R has a stiffened Chassis, 4 point front Strut Bar - not just a lowered with bigger dampers / stiffer springs standard chassis setup. Theres even strengthining added to the rear strut towers just like the type r Integra's / Civics and bigger sway bars.
I think the added HP figure is more than likely due to the fact it runs EPS, so it doesn't lose any power running the power steering pump??
Old Oct 8, 2009 | 02:54 PM
TRA_Blaze's Avatar
wow thanks for shining the light on the differences i thought they were interchangable names (EuroR & Type-R) so i guess i stand corrected and should put it like this ...
nice CH1!! lmfaoooo
and i have to agree that manifold is eye candy every time i check in on this thread thats the first thing i scroll down to see lol
Old Oct 8, 2009 | 06:38 PM
Whats Up DOHC's Avatar
That build is epic... Jesus Christ!
Old Oct 8, 2009 | 09:55 PM
funnyboy's Avatar
Type-R went first
Ok lets not got too hard on this. Both cars are great, no matter the differences. At this point all that is interesting in this story, is that European Honda cheated one Type-R model from japanese and built it first. So Japanese guys just god angry and although they didnt need to build that car for any competition purposes they still couldnt stand the fact that European Honda engineers in UK made a real competition car under Tyoe-R name.
There is some video from Top Gear, that is worlds most famous car show, this series is made at 1998 if im correct.
http://www.youtube.com/watch?v=DPMZtAnKDuE
Old Oct 8, 2009 | 09:59 PM
funnyboy's Avatar
Originaly nothing was wrong, i still have my 11:1 pistons lying at garage floor, just as the rods. Can sell them to sameone, very rare.
Mahle Golds that you can see in first pictures are just ****, i didnt do anything, they just broke. End of story. Piece of crap.
I love your quote about the boy. :D
Old Oct 9, 2009 | 06:43 AM
lunarone's Avatar
Truly amazing work and great pictures. Looks like nothing I've seen before, and it looks awesome! Can't wait for more updates.
Old Oct 9, 2009 | 07:30 AM
t3am spotlit3's Avatar
holy **** that some nice fab work bro
Old Oct 11, 2009 | 03:52 PM
GlassJAw's Avatar
I'm starting to feel like a school boy thats just ha a sample of the latest confectionary available and want more - have you done anything to the beast over the weekend??
Any pictures of the original setup with the crappy Mahle Golds??
I sometimes wonder if the Type R Accord is what inspired the new FD2 Type R Civic's as the Europeans have the hatchback version correct??
You're also very correct about the Japs getting mad that Europe made a Type R Accord and decided they had to do something about it!
Old Oct 12, 2009 | 08:03 AM
213374U's Avatar
0x5359-0055
Community Builder
Awesome build
Love the new mani. Quick question though, your placement of the oil cooler with the old log mani, how well did that work for you? Assuming you have an oil temp guage of course.
Old Oct 12, 2009 | 01:18 PM
funnyboy's Avatar
The best tool for finding unplesant sound locations in any rotating or moving car part.
So, i cant see anything bad in valve guides or valves themself. I see that there is EGR channel, maybe it is the one thats making that knocking noise at low rpms?
I have no idea where to go from there. Actually i have i just wanted to say so.
I think i will take the head apart and will take it to machine shop so they check the alignment of guides to valves etc. What you people think about it?
Also bought a new bumper.
