SRS Problem!
Old Oct 7, 2009 | 09:12 AM
Black Diamond's Avatar
Default SRS Problem!
I recently had to replace the electronic ignition on my 94 ex coupe, I had taken the steering wheel off and etc, I did everything by the haynes manual and such i fixed the problem and put everything back the same way it came off, that being said i started it up and the SRS light came on and now wont go off for some reason. I have diconected the NEG. battery cable and that did nothing to help Right now my air bag is unpluged for safety reasons.
Can anyone add some insight to the problem, i have to go through the Inspection lanes in a month so i need to get this fixed..
LMK what you have Honda Tech,
Thanks
-NICK
Old Oct 7, 2009 | 09:57 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: SRS Problem!
your airbag being unplugged will cause that light. plug it back in or take out the SRS light bulb in the cluster
Old Oct 7, 2009 | 10:01 AM
I know that it being unpluged will cause the Light to stay on, what i was asking is how to make it go out! I pluged it in and it still stays on, i disconnected the Neg. Battery cable and it stayed on, so i unplugged it cause i dont want the bitch deploying in my face when im driving!!..
Does anyone else have any other thought on how to fix this problem??
Old Oct 7, 2009 | 12:06 PM
BUMP!!!
Old Oct 7, 2009 | 02:05 PM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
Remove the bulb
Old Oct 7, 2009 | 02:21 PM
durfeec's Avatar
once i found a way to reset the SRS system in the fuse box with a piece of wire. also its possible you broke your clock spring removing your steering wheel. my ej didnt have one when i bought it and the horn or cruise also didnt work.
but search like SRS reset here and google. pretty sure thats all you need to do.
aandrewcc
Honda Civic (2001 - 2005)
Apr 9, 2009 07:04 AM
theeogflip
18
Apr 6, 2008 04:23 PM
b18c-ivic_gsR
Oct 20, 2004 08:09 AM
DynastyRacer22
Sep 28, 2004 01:03 PM
