Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
crankshaft bearing
Old Oct 7, 2009 | 07:17 AM
thunderboy's Avatar
Default crankshaft bearing
Hey guys i have a question
I just wanna know which lower main bearing i need to buy to change...Cuz there are like 5 different colours...
Can somebody help me out here??
Cuz i need to order the right colour.
( or doesn't colors matter?
Old Oct 7, 2009 | 09:02 AM
chiggin's Avatar
Default Re: crankshaft bearing
since when do crankshaft bearings come in different colors?
Old Oct 7, 2009 | 09:16 AM
civicgsr's Avatar
The "colors" are varying thicknesses usually a dot on the side of the bearing (someone will need to verify this). You would check to see which color was originally installed and then measure to see if you need a different thickness.
Old Oct 7, 2009 | 09:19 AM
dirtySOHC's's Avatar
since the beginning of time
OP,
What color were the ones you are replacing? buy the same ones. but, it's always wise to plastigage it for the correct clearance then buy the bearings that those measurements fall into (color).
what happened anyway?
Old Oct 7, 2009 | 09:50 AM
i-VTEC_DOHC's Avatar
you might as well just buy them all.
since you dont know which one to buy.
Old Oct 7, 2009 | 10:00 AM
or measuring the clearance can be the difference between spending $10 or $60. and that's if he just buy's the lower main like he's asking. normally when you change out bearings you want to change them out as a set. upper and lower. so he could spend $120 if he buys all the colors.
EDIT: and that's just one set. if he bought all the colors of upper and lowers to change out all his main bearings he could spend $500. these are just aprox. costs depending on where he bought the bearings but you see where I'm getting at.
Old Oct 7, 2009 | 01:52 PM
tomh1979's Avatar
you are correct, also he could get a chart from a local honda dealer, we actually keep our's on hand since alot of customer's ask for bearings, the charts tell you where to look at on teh crank so you can figure out which bearings belong where on the crank.
Old Oct 8, 2009 | 07:33 AM
chiggin's Avatar
OIC. The crank shaft bearings that I work with on a daily basis are all the same color. That's why I was asking. Thanks for informing me.
Propulsion
Jul 31, 2007 03:37 PM
yaoming315
Jul 21, 2007 11:46 PM
unknown0001
May 19, 2006 07:38 AM
tek_civic
Aug 9, 2003 06:12 PM
