what main bearing and rod bearing do i need? d16z6
ok so my number 4 rod bearing is bad and i assume the main is as well, so my question is what color of each do i need to buy to replace them? it is the number 4 piston(the one furthest from the dist) last one on the drivers side. i need to know which one specifically i need to buy as apparently they are color coded and don't work in eachothers spots. thanks for the help!
Re: what main bearing and rod bearing do i need? d16z6 (tek_civic)
your gonna wanna pull the crank and make sure its within spec before you get your bearings. Also, just because #4 rod is bad doesn't mean #4 main is bad.
D16SohcVtec
04-22-2008 07:50 AM
