installed new speakers; Very Loud high frequency beeps, no music.
Old Oct 7, 2009 | 06:23 AM
JDMB20TDA's Avatar
Default installed new speakers; Very Loud high frequency beeps, no music.
just installed a set of speakers into a car, after wiring it all up I went to test it out.
played no music.
it just made a series of extremely loud high frequency beeps.
volume at head unit doesnt effect volume at speakers( @ 1, the speakers were screamin).
there is only 2 feet of wiring going to the rear channel and its perfect only one solder joint.
I have the front channel disconnected and it still does this.
I didnt mess with any of the wiring before the amp, previous owner installed it so id guess thats where the problem lies.
they are a set of brand new kicker 6x9's, with a kicker 4 channel amp.
ive never had this problem before and Im stumped what should I check first, and has anyone experienced this before?
Old Oct 7, 2009 | 07:15 AM
mrdeadman's Avatar
They let me pick
Default Re: installed new speakers; Very Loud high frequency beeps, no music.
What is the model of speakers, hu and amp?
Did you have other speakers in the car before that worked when run off the amp?
Old Oct 7, 2009 | 07:33 AM
JDMB20TDA's Avatar
pioneer deh p7500mp
Kicker 4 channel amp
Kicker 6x9 coaxial speakers in the rear deck.
I dont have the front channels hooked up and there is only about 3 feet of speaker wire going to the rear speakers.
Old Oct 7, 2009 | 09:07 AM
mrdeadman's Avatar
They let me pick
What are the numbers on the amp and the speakers?
If you bypass the amp and hook them directly to the hu do they output the music?
Old Oct 7, 2009 | 09:42 AM
JDMB20TDA's Avatar
havent even tried, the car never had rear channels hooked up.
JDMB20TDA's Avatar
the amp is a 30watt rms per channel I was using just to get everything working.
the speakers can handle 90 watts rms so they are just fine.
Old Oct 7, 2009 | 11:44 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Could be a bad head unit or amp. Or rca cables. I would try the radio to see if its the problem and then move on to the amp.
Old Oct 7, 2009 | 11:58 AM
JDMB20TDA's Avatar
thanks guys ill give it a try, is there a way I can check with an dmm to find a short or open?
Old Oct 7, 2009 | 04:26 PM
mrdeadman's Avatar
They let me pick
Disconnect the speakers from the amp. Run the multimeter across them in the ohms setting to check for continuity. You can check the rcas by unplugging them and checking for discontinuity between the ground and the center terminal. Then check for continuity between the center terminals on each end, and do the same for the grounds.
Civic Si Kid
Audio / Security / Video
Feb 28, 2009 07:42 PM
Cody2289
14
Feb 11, 2008 09:28 AM
TheTealHatch
23
Oct 11, 2006 08:05 PM
Luserkid
Sep 24, 2004 04:19 PM
Torridcivic
Sep 23, 2003 07:49 PM
