mugen activegate rotor replacement
I have the activegate brake kit on my ITR as of right now and I would really like going to a blank oem rotor....does anyone know if there is anything that will replace the activegate rotor such as s2k, TL, RL, rsx-s ....there has to be something that will work in its place..
if anyon has the ability to look and find out or know where to find out please let me know.
thanks.
thanks.
Not sure about OEM blanks, but on Wilwood's website they list the hats and rotors seperately. I'm sure with a little research you can come up with some dimensions that would work using the rotors you have now as a guide.
Some of the rotors in the size you would probably be looking at aren't very expensive either...
I'm pretty sure the rotors are from early model S2K. Ask one of the guys in the S2K forum to post pics and dimensions (backspacing is the most important because the diameter is 300mm/11.8in) of an OEM disk.
My SS Works brake kit uses re-drilled Mugen active gate rotors.
Hit brembo's website. You can look up the exact specs of the oem s2k rotor in their catalog.
However as the previous poster stated, I'm 99.9% sure the activegate setup was an s2k setup.
