What kind of mani can i use?
Old Oct 6, 2009 | 07:33 PM
hondaluver12's Avatar
Default What kind of mani can i use?
I have a d-series with a dsm t25 turbo, i'm using the stock hf mani with a adapter plate going on to the turbo. But i want a aftermarket mani but i don't know where i can get one that has the same bolt pattern as my turbo. its not the stander t25 flange, its something diffrent...
Old Oct 6, 2009 | 07:34 PM
Turbo_Ted's Avatar
Default Re: What kind of mani can i use?
well, what flange is it? post a pic
Old Oct 7, 2009 | 07:12 AM
90civichbsi's Avatar
if your turbo is internally gated you could use a greddy manifold like here:
http://www.hondamarketplace.com/show....php?t=2522531
or http://www.godspeednet.com/servlet/t...CRX-D15/Detail
although with this last option the wastegate placement is awful. I would only reccomend that one if your going to block it off and stick to the internal wastegate
if your looking for tubular you would have to go custom since most are made for a t3 flange
Old Oct 7, 2009 | 10:07 AM
aonther option is edelbrock: http://www.jegs.com/i/Edelbrock/350/...0002/-1?CT=999
Old Oct 7, 2009 | 10:13 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
they make t25 to t3 adapters
WestTxSR20
Aug 18, 2009 12:19 PM
SoHc94
Oct 12, 2008 06:36 PM
omghiii
Sep 8, 2008 11:48 PM
hatchinprogress
Welding / Fabrication
Jan 11, 2006 08:04 PM
AVXHATCH
Mar 9, 2005 05:33 PM
