Project 97 coupe shaved tucked lots pics
Well im a noob here. Here is some pictures of my project Ive been building for the last year. Let me know what you think This is my first time on honda-tech. I have took pictures throughout the entire build so i have lots more. I have done all the work myself including body/paint and tuck of coarse.
Just after being polished rolled out side to check it out in the sun
Engine Bay all smoothed over and freshly painted
Brake booster/master with tucked stainless hardlines
Side pic with glass installed
Passenger side pic
My chassis harness tuck
Inside pic of dash
Relocated Fuse block
Rear disc brake conversion with drilled and slotted rotors
Civic si front suspension conversion with new rotors
Bay with filler on it
Bay after being welded and grinded
Just cut the 1/4 off getting ready to replace
Stock Bay
Stock bay after being stripped
My first brake tuck
Chassis being undercoated
Just after being primed
Doing the body work
Body work done after new (used) 1/4 was installed
Used 1/4 welded on
Fitting the 1/4
Used 1/4 drilled and ready to be fit
All stock
in the booth jambed
Being polised
The car in base
Cleared
4door handles
Si lip
Parts
I have lots of pictures let me know what you guys think
Passenger side pic
Inside pic of dash
Stock Bay
My first brake tuck
Doing the body work
Used 1/4 welded on
Fitting the 1/4
All stock
in the booth jambed
Being polised
The car in base
Cleared
4door handles
Si lip
Parts
Looks like a really thorough job, and I can appreciate that a lot. Just for saving future headaches, I would lose the drilled/slotted rotors and just use OEM blanks though.
Thanks but i have never had a problem with my other drilled and slotted rotors on my hatch. what is the prob with them?
Yes i do. I have put in many hours sanding cars
Thanks and its lime yellow effect off of an 04 saab
Looks rad I'm about to take my first venture into prepping a car for paint. Any advice or good resources I should check out? Yours looks so epic nice work.
go to the book store and buy a book call how to paint believe it or not good info in there. Other then that just remember paint dont stick to unsanded surfaces
Is this the book you speak of?
http://www.amazon.com/How-Paint-Your...6497564&sr=1-2
