ys1 tranny problems!!
ok got a ys1 cable on my b18b1...lost my 5th gear about a week ago ugh so today i drive to work besides my 5th gear gone everything seems fine....then get into my car to go home after work and once i get on the highway crusin the car starts feeling like its bucking lightly...almost like its trying to stop itself...its on and off here and there...engine rpms dont really flucuate or anything...also sometimes in start of 1st i will get a lite chatter from the tranny side of the car
my buddy said possibly trannys trying to lock up on me...other friend said maybe it has no fluid...help help help!
so your 5th gear stopped working and you didnt inspect and drain the fluid, AND continued driving it and are NOW wondering why its doing weird stuff? Your buddy already told you the most important step you should have checked already, yet you didnt. instead of checking you took the time to make this post and ask our opinion. Whats wrong with you?
PS your tranny is fine it is supposed to do that
thanx dad...didnt need the smartass reply but thanks for wasting my time...posted on here for some help cause i believe thats what this website is for..anybody else thats not an a**hole can help me out? thanx
yea i figured that...just didnt know if anybody else on here had the same issues with there ys1...i really need it to last another week before i have time to change it but idk..honestly how long do u think it will last before it locks up? probably unpredictable huh...gonna buy a b16 lsd tranny from a friend...see how that works
No offense but it takes about 2 minutes to remove the fill plug from the tranny to check the level. it takes longer to start up the computer and post. Im not trying to be an *** but you already got good advice. I thought it would be common sense to drain it to inspect for metal after you had 5th stop working.the trannys are usually reliable, but not if they have no oil in them.( or parts of 5th gear or a fork floating around in them)
well i understand it takes 2 minutes but i work 7 days a week and truthfully i could give 2 ***** about this trans as long as i can drive to work in some kinda gear cause its my only car for now..tranny was reliable for 3 years and 2 clutches...was about 8 o clock and dark when i got home and my comp was already on and logged onto ht
if time can be made tomorrow i will drain and refill maybe i can make it live for another week till i get my other one...hopes and dreams lol
I just bought a 92 integra rs with a YS1 5 speed tranny, and i amy new to manual trannys, learned to drive it just fine, but when the engine and tranny is cold i have no problems, it goes through all gears perfectly, but once the engine/tranny get to operating temps, the 2nd gear slightly grinds going into gear but not all the time, the 3rd gear does the grinding noise all the time once engine temp gets to normal operating temp, when cold it doesnt.
i know automatics use atf fluid, im not sure the manual does or not, i dont want to keep driving it and end up damaging the tranny, is there fluid in the ys1 tranny and if so how can i check the fluid level and or flush it out and refill the tranny, if someone can take pictures on where and which holes are the drain/refill holes, i need help, im new to manual trannies...
if you can help, email the pictures to my email,
at adamnfs@live.com ,
thank you in advance...
Back on the OP's problem. You were probably low on fluid and caused it to grind and break apart. If its just a LS transmission junk it but if its a B16 transmission you can rebuild it for cheap. Cable B16s are hard to come by when you need it for cable tranny.
if time can be made tomorrow i will drain and refill maybe i can make it live for another week till i get my other one...hopes and dreams lolThread
plonger
Apr 23, 2006 10:48 AM
