Help!! Guage cluster
Old Oct 6, 2009 | 10:18 AM
cst90turbo's Avatar
Default Help!! Guage cluster
I have a 1996 civic ex. The Guage cluster all of a sudden stopped working. None of the guages work but it does light up. Any ideas? I have check each fuse and none of them are broke. thanks
Old Oct 6, 2009 | 10:52 AM
Former User's Avatar
Default Re: Help!! Guage cluster
Replace 7.5A fuse #25 under the dash with a known good fuse.
Old Oct 6, 2009 | 11:35 AM
cst90turbo's Avatar
already did that..Should i check the actual fuse wire or does that exist. thanks
Old Oct 6, 2009 | 12:24 PM
If you are absolutely sure that fuse 25 is good, then check for a loose connector at the rear of the cluster.
Old Oct 7, 2009 | 05:50 AM
cst90turbo's Avatar
Everything is cool now. I ended up replacing 8 fuses to all kinds of different things. I somehow skipped over #25 or put in a faulty fuse before. Now the last step I have is neither front blinkers work. No low beam on passenger side, only high beams on both and passenger side running light works not driver side. Hopefully a bulb issue? Everything else is fine.
Old Oct 17, 2009 | 11:26 AM
h22ej8's Avatar
I have a similar issue, but my cluster (everything on it, rpm, speed, temp, gas, turn signals) only works when it wants, it just wigs out driving down the highway. Turn signals only work half the time.
This just started up thurs night after i went to start the car and the battery was dead, jumped the car and everything seemed ok. Jumped it again friday morning to drive to work, nothing worked again. Put it on the battery charger for about 5 hours and played with the connections on the back of the cluster. Fixed the issue for the 3 mile trip home, then it started wigging out again.
I've been searching around honda-tech, google, etc. but I haven't found any answers yet :/
Old Oct 17, 2009 | 11:33 AM
boxeocampeon's Avatar
could be ****ed up wires in the back of the cluster
Old Oct 17, 2009 | 01:05 PM
h22ej8's Avatar
Already checked that. I've checked all of the wiring i can get to throughout the whole dash without actually pulling the dash out.
Going to pull the dash today i think.
honda_conversion
Jun 22, 2007 11:31 PM
timntam
Feb 3, 2006 11:10 AM
ccfab
Jan 30, 2006 02:07 PM
SiR HatchAlot
Mar 28, 2004 09:31 AM
BoostedSi
Feb 23, 2003 08:59 PM
