Keyless entry remote Programming? on EM1
Old Oct 6, 2009 | 08:06 AM
bernabeguzman's Avatar
Default Keyless entry remote Programming? on EM1
Hi I was wondering if anybody knew how to program the keyless entry on a 99-00 honda civic? I have found by searching 96-98 keyless entry programing and tryed it buy it dont work. I have brand new battery on my remote and I know it works because it came from another car working.
I have programed my moms 03 toyota avalon a couple times because she keeps on loosing her remote. I went to a couple of instrucitons of opening the door and sticking the key in the igntion. It has worked well on my moms car. They wanted to charge her like $200 at the dealer to program the key and I did it in 5 min for free.
So what i was wondiein if anybody knows the instruction of doing this if not I might take it in to the dealer and pay them to do it.
Old Oct 6, 2009 | 02:28 PM
ferio252's Avatar
Default Re: Keyless entry remote Programming? on EM1
Is this the method you used??? Is it an OEM keyless entry?
KEYLESS ENTRY PROGRAMMING
Have all remotes for the vehicle on hand.
Make sure all the doors and rear hatch/trunk are closed during programming.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.
7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will "pop".
Old Oct 6, 2009 | 11:28 PM
TheJGB3's Avatar
Old Oct 7, 2009 | 05:17 AM
Lasky's Avatar
does this work for all years? im bout to scoop a remote for my Ex EG since the guy i bought it from lost his..
Old Oct 7, 2009 | 05:22 AM
acake em1's Avatar
Colonel Cake Mix
i know for sure this works for an em1
Old Oct 7, 2009 | 07:20 AM
Targa250R's Avatar
be professional
'99+ only.
'92-95 Civics didn't come with keyless entry in the US.
Old Oct 7, 2009 | 03:36 PM
92-95 did come with keyless entry but they will probly take a different procedure, I tryed the 96-98 civic program but didnt work im just going to wait till tomarow and and conect my battery to see the stuff on here works. im excited
Old Feb 11, 2010 | 12:59 PM
Episode's Avatar
rather than create a new thread, i'll add to this one. the keyless entry in the em1's is its own stand alone unit right? the reason i ask is mine quit working a while back. it worked for a while even after swapping the factory radio out, so i'm assuming it's a stand alone system. i want to see what i can do about fixing it. when it started acting up, it would intermittently work, like the battery was dying in the remote. finally when it completely stopped working i replaced the battery, but still no luck. any ideas?
Sashin
Jan 27, 2014 11:43 PM
wrod7
Audio / Security / Video
11
Nov 27, 2009 01:58 AM
VTEC_Du_Ma_Mai
Oct 15, 2007 03:30 AM
