How to install power steering?
Old Oct 5, 2009 | 08:05 PM
SHG_Claudio's Avatar
Default How to install power steering?
So I have a Civic Si that had power steering removed. I really can't stand how hard it is, what materials and tools are needed to install it back on there? How much would this run me? Any help is appreciated thanks.
Old Oct 5, 2009 | 08:26 PM
ej1love's Avatar
Default Re: How to install power steering?
eg si hb? with a Z6 still?
Old Oct 5, 2009 | 08:42 PM
Yup, I hope it wont be too hard, I mean Im sure there are leftover lines and the rack is still a power steering one.
Old Oct 5, 2009 | 08:45 PM
ej1love's Avatar
well do u see lines in the grille? and is anything looped, cause thats the only way to remove?
Old Oct 6, 2009 | 06:23 PM
Yeah theres lines/hoses in the grille and behind the drivers headlight. Theres one hose thats got a screw in it hehe.
Old Oct 6, 2009 | 06:52 PM
Lasky's Avatar
parts needed
1. power steering pump
2. belt to run the pump
3. power steering fluid reservoir
4. hose to run from rack to pump
5. hose to run from reservoir to pump
not sure on prices but after that its not hard to install.. make sure you bleed the system properly and never let it run out of fluid while doing so.. very bad for rack
Old Oct 6, 2009 | 07:52 PM
Sounds good, thanks mate.
Old Oct 7, 2009 | 04:45 AM
Lasky's Avatar
oh and there should be a plug from the harness that plugs into the line running from the rack to the pump.. best way to bleed is put car on jack stands in the front then after youve filled the reservoir to the cold line (bottom one) spin the wheel back and forth (with the car off) until the fluid goes down.. repeat until fluid stops going down.. then start the car.. some bubbles should come up in the reservoir, turn car off and spin wheel back and forth 15-20 times then turn car back on.. repeat until no more bubbles
good luck man
greg677
Nov 12, 2014 04:18 PM
EM1 Resto
Sep 20, 2009 08:13 PM
yoffer
Oct 9, 2008 04:03 PM
Anubyss
Nov 6, 2006 07:59 AM
90civicSi VTEC
Jan 1, 2005 09:56 PM
