What stock cars used the TD04H turbo's?
Old Aug 28, 2002 | 07:17 PM
pelotudo's Avatar
Default What stock cars used the TD04H turbo's?
I am looking for the banjo bolt for the oil feed line, and wanted to know what stock cars had this turbo on it? I heard the Galant GL4 I believe, and something else? You guys think the dealer might have these? I tried a 91 300ZX TT, but theirs is a M12x1.25 instead of M10x1.25
jB
Old Aug 28, 2002 | 08:31 PM
stick's Avatar
Default Re: What stock cars used the TD04H turbo's? (PeloTudo)
thats easy>WRX
Old Aug 30, 2002 | 12:50 PM
Brightazzsi's Avatar
Default Re: What stock cars used the TD04H turbo's? (stick)
1st gen automatic dsm's (eclipse and talon)
Old Aug 30, 2002 | 06:25 PM
Sprockets's Avatar
Why don't you just buy a 10 x 1.25 banjo bolt from someone like Goodridge? While you're at it, why don't you buy their 10mm to -3AN banjo adaptor and use AN fittings? Anyway, just make sure the bolt is not only 10mm x 1.25 but the proper length so enough threads are left over after going through the banjo. I hope you're using new copper washers. Here is a link to the page listing banjo bolts at Goodridge's website:
http://www.goodridge.net/cat/topframe.html
The part numbers are listed incorrectly, though:
992-02-32 should be 992-03-32 which is a 10x1.25 single banjo bolt w/20mm under hex length
992-02-32L should be 992-03-32L which is a 10x1.25 single banjo bolt w/25mm under hex length
I just ordered the 32L for my TD05H-18G with the -3AN banjo adaptor and 2 copper washers.
Old Aug 30, 2002 | 06:28 PM
Sprockets's Avatar
Default Re: What stock cars used the TD04H turbo's? (Evil Beaver)
Sorry, here is the proper link:
http://www.goodridge.net/cat/600700/banjobolts.html
Burningrambo
Oct 29, 2014 10:05 PM
SupaTeg
Aug 3, 2003 03:15 PM
fe519
Jun 19, 2003 05:36 PM
ZCHF2
Mar 12, 2003 12:52 PM
sackdz
Apr 10, 2002 11:13 AM
