Oil line size 4 S372
I wanted to know what size oil feed line you guys are running on your S372 turbos , Iam running a -3an right now and I notice I get some oil in the inlet of my turbo and wanted to know if this was normal or if I should switch to a -4an line for the turbo to drop the pressure, thanks
it should be a -4AN and no smaller and no oil restrictor.
here is another thread covering the same topic!
https://honda-tech.com/forums/showth...=s372+oil+line
ok , thanks guys I will swap it over this week to -4an line , I guess the -3an is to much pressure because I get some oil residue in my inlet , the -4an will drop pressure but flow more, makes sence.
Correct. Those S372s use a very large turbine shaft for the wheel that matches to it, so you'll need all of the lubrication and cooling effects you can get from the oil used.
sampol999
Sep 3, 2006 01:09 PM
