coolant line where does this go?
Old Oct 5, 2009 | 01:02 PM
Frost7177's Avatar
Default coolant line where does this go?
I have a d15b bottom end matted to a z6 head . I have a coolant line that i cant find where the other end connects to. This hose is located on the back of the block its in between the water pump and the thermostat housing on the big metal tube that transfers coolant to the water pump thats the hose that i need to find where this plugs into I see a spot on my intake manifold on the very right side next to the vtec selonoid. Is this the correct spot?
Old Oct 5, 2009 | 01:08 PM
Former User's Avatar
Default Re: coolant line where does this go?
Old Oct 5, 2009 | 05:55 PM
civic_r87111's Avatar
LOL.....
Old Oct 5, 2009 | 05:59 PM
93egSLEEPER's Avatar
that one sounds like the "loop" hose that goes from the water pump neck to the thermostat housing. there should be a 1/8" nipple on either one not covered.
Old Oct 5, 2009 | 06:07 PM
Frost7177's Avatar
thats man i figured it out now only for this spark problem.
thom1488
May 27, 2018 10:49 PM
crxb20ed
Jan 5, 2005 12:22 PM
CRX Lee
Mar 15, 2003 11:06 AM
Allstar
Feb 26, 2003 05:55 PM
