Vtec question
Hey guys got a question, I have a 95 civic ex coupe with a d16z6 an was wondering how you can tell when vtec kicks in I can't feel or hear a difference so was curious how to tell if it's even working? Thanks for any help you can give me
What does it mean when there's oil seeping from the solenoid? Vtec is new to me lol I love this car an have major plans when money allows but for now just tryin to learn the basics on how vtec works thanks for all the help. If vtec isn't workin will it hurt the motor at all? I would think not but you never kno lol I've heard dohc motors vtec kick in sounds like a raspy noise but never knew if mine did
single cam vtec is about as effective as farting while running. its not very noticable (more noise then anything if you have an intake) and possibly a slight pick up in RPM. i wouldnt worry about it too much.
Lol I notice when I fart while runnin I go faster hahaha an feel better haha thanks for the info I don't have an intake all stock (stock sucks) I plan to build the sohc cause of the stupid laws in Cali I jus don't want to deal with reffin an the other bs besides how pissed would someone be to have a sohc kick there *** lol an I see oil commin from the back of the solenoid where it mounts to the head should I get a new gasket an could the oil be affecting how it works?
thats just a typical honda leak man. i have had my b16 head apart and resealed many times and it still manages to leak even with a new gasket and honda bond. as long as it is just a small seep i would not worry about it too much.
The cel comes on every once in a while when I hold it wot like gettin on freeway an only goes off when I shut the car off but can't notice a difference at all in any rpm range
next time it pops on DONT turn off your car. you will need a paperclip to loop the ecu and pull the code. there should be a green plug on the right hand side of your dash tucked up under the glovebox... that is where you loop it. put each end of the paperclip in each hole. you will need to watch the CEL and count flashed. short flashes are "1" and a long flash is "10". add them all up to get the code
Sweet next time it comes on an I can remember I'll do that what should I do after that? An is there another way to get the code? Like a code reader or something just curious
schtozo
11
Feb 14, 2004 04:31 PM
