cluster gauge lights dim with a 12" W7
Old Oct 4, 2009 | 09:48 PM
aznjay510's Avatar
Default cluster gauge lights dim with a 12" W7
i have 1 12" W7 with a Jl 500/1 amp.
4 gauge power wire, with a 60a fuse
8 gauge ground for the amp.
the lights dim when the volume is up really high...
stock alternator, stock ground wires...
will changing the ground wires take care of the problem? thanks
Old Oct 5, 2009 | 04:15 AM
fcm's Avatar
fcm
Old Fart
Default Re: cluster gauge lights dim with a 12" W7
The amp ground needs to be the same gauge as the power lead to start with, [keep ground lead as short as possible] you should also add a 4ga ground from batt. to chassis.
Where have you got the amp grounded?
What type of fuse are you using on the amps power lead? 94
Old Oct 5, 2009 | 06:57 AM
edzy's Avatar
Civics have terrible electrical systems. i'd do the big 3 and run 0 gauge from the battery to the distro then 2 gauge from the distro to the amp.
Old Oct 5, 2009 | 10:24 PM
acake em1's Avatar
Colonel Cake Mix
and get a cap
Old Oct 5, 2009 | 10:48 PM
ekbublboy's Avatar
First off hows your battery,power and ground cables,alternator?start by fixing the cheaper stuff and work your way to the expensive stuff(.i.e upgrade the power and ground cables along with the starter,fuse box,motor and trans cables then upgrade the battery(interstate or optima)then upgrade the alternator then add a cap)
Old Oct 6, 2009 | 05:44 AM
fcm's Avatar
fcm
Old Fart
There is no need to use anything bigger then 4ga power cable for a JL Audio 500/1, "0 gauge" is way overkill and adding a "distro", [distrobution block] would only add unwanted connections.
I agree with ekbublboy check and make sure the stock electrical/charging system is good first. 94
96 EX
Audio / Security / Video
29
Mar 30, 2009 11:13 AM
LuckyHonda839
Mar 5, 2008 04:01 AM
jmai86
Mar 3, 2008 06:21 PM
kroze
20
Oct 29, 2006 02:25 AM
BlackAckeR
Jan 19, 2002 08:27 PM
