Which guage for distributor blocks?
Old Mar 3, 2008 | 12:55 PM
jmai86's Avatar
Default Which guage for distributor blocks?
I'm setting up a new system powered by 2 amps (sub, speakers). Totalling around 550w RMS for all components.
I'm going to use a distributor block for power and ground, but I'm not sure how they work in splitting current.
The amps recommend 4 guage for power and ground, so what gauge should I run from the battery to the blocks? Blocks to amps?
What gauge wire should I use to upgrade the battery - chassis ground?
Old Mar 3, 2008 | 01:26 PM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Which guage for distributor blocks? (jmai86)
Power Wire and Fuses / Holders ("what size do I need?")
2 gauge to the block and 4 to the amps is MORE then enough!
Old Mar 3, 2008 | 02:07 PM
jmai86's Avatar
Default Re: Which guage for distributor blocks? (White Smoke)
Thanks, I did check that but it was a little confusing in terms of my situation.
So 2 into 4 gauge it is.. Should the battery ground be 2 gauge as well?
Old Mar 3, 2008 | 06:21 PM
fcm's Avatar
fcm
Old Fart
Forget the distribution blocks, run 2 power leads, one for each amp, run the ground leads from the amps directly to the ground point, preferably the cars floor pan and a common ground point for both amps.
There are three very good reasons to do it this way....
1- It is cost effective, you save the cost of the splitter bloc, [ground] and distribution block and fuses, [power] cost more then one more main fuse.
2- A direct connection is a better connection, every connection point is a point of resistance and because of oxidization resistance can and will increase with time.
3- It is better for SQ, "electricity takes the coarse of least resistance" when the high-pass amps power supply is "electrical" closer to the low-pass amps power supply, then the low-pass amp is from the batt./alt., [when distribution block is used] then the low-pass amp will "draw power" from the high-pass amp when it needs it, [cranking the bass], this results in a loss of power, [current] to the high-pass amp and distortion, [most noticeable in distorted vocals when bass hits].
It also allows a cap to "stiffen" the power supply of the low-pass amp only, [not needed for the high-pass amp]. 94
zeroartgfx
Audio / Security / Video
Oct 19, 2015 08:06 AM
Chadcg88
Jul 4, 2015 10:23 PM
aznjay510
Oct 6, 2009 05:44 AM
kroze
20
Oct 29, 2006 02:25 AM
redman223
15
Jun 10, 2003 06:15 PM
