idling problems already cleaned iacv and adjusted screw
Old Oct 4, 2009 | 05:46 PM
liquidx's Avatar
Default idling problems already cleaned iacv and adjusted screw
anyways so i spent all day cleaning the IACV and seafoaming the car. So i turned the car on and the idle which is low is prolly like 300 and i've been adjusting the the idle screw and still it doesnt go up ( im turning ccw) now when the car has the IACV electrical plug it idles low and with it off it idles at 1.5k revving up and down wanting to go higher.......it idles fine and drives as if its real responsive with the plug off but when i put it in its the same old........idle problems where it dies off at a stop.......its an automatic and well i've turned the screw about 4 turns probably and still the idle still stays the same at 300 ionno what to do im just frustrated.......any help would definitely help
Old Oct 4, 2009 | 06:04 PM
acake em1's Avatar
Colonel Cake Mix
Default Re: idling problems already cleaned iacv and adjusted screw
you might need to replace the iacv cause sometimes cleaning it doesnt fix the problem.
Old Oct 5, 2009 | 06:47 PM
liquidx's Avatar
mmmmm interesting
Old Oct 5, 2009 | 06:58 PM
acake em1's Avatar
Colonel Cake Mix
do u have a vacuum leak or anything, cause sometimes when u clean your iacv those hoses crack and leak, so id check that too
RinzEG6
Nov 24, 2014 12:02 PM
dc4b20
22
Dec 3, 2012 09:54 PM
SuperSlowEF8
11
Sep 17, 2011 04:00 PM
SHG_EasyE
Apr 2, 2006 08:10 PM
redman223
Jun 26, 2003 08:20 PM
