H22 axles for civic
I want to buy new h22 axles for my '93 Honda civic coupe that has a h22a swap. I am looking at the ones on eBay and found some, but I have a question. Should I get just the 2 axles or the h22 axles with halfshaft. They are about $180 from eBay. Are they decent axles? They say in the auction that they are direct bolt on. Anyone tried these axles? Also halfshaft auction, or the auction with just the 2 axles?
Post the link for the axles. No one can help judge whether they are good if we can't see them.
There are some shady dealers on ebay, so you gotta be careful.
http://cgi.ebay.com/ebaymotors/Honda...=p4506.c0.m245
This one has the halfshaft. Do I need a halfshaft? Or this auction, this one is just for the axles:
http://cgi.ebay.com/ebaymotors/Swap-...=p4506.c0.m245
Or I also found these:
http://cgi.ebay.com/ebaymotors/92-95...=p4506.c0.m245
a little more expensive though. Anybody have any inputs on these 3 eBay axles? Anybody try them?
Ebay is ebay; sometimes you get a deal, some times you get ripped off. As for the halfshaft, I would contact the sellers who aren't selling them and ask which halfshaft the axles will work for; the H-series or F-series. That way you'll know if they work with the one you have (assuming you have one), and whether the seller is actually knowledgeable enough to buy from. Personally I wouldn't buy those "400hp" axles, simply because it's on ebay.
Will those axles fit my civic if I have front/rear integra disc brakes? Or do I have to get the integra h22 axles? I don't think the brakes will matter, but just asking to make sure.
I would have to say with something like that you get what you pay for. Spend the little bit extra and get either drive shaft shop or hassport axles. That is what it suggest cuz i got srewed with a cheap set.
As long as you didn't do the Type R 5-lug conversion, specifically swapping in the hub assembly, then it won't be an issue.
Get the hasport mounts and the Hasport axles, please note when you order the axles from hasport that you let them know if you have the LSD or non LSD transmission as the lengths of the axles are around i believe it was a quarter inch difference.
I had the shorter axels in my civic and they would pop in and out all the time "not causing problems" just making noise and I had to have the longer axles..
NO EBAY.
NO EBAY.
