My first manifold (2jz, no shit!)
Old Oct 4, 2009 | 03:17 PM
Janz99's Avatar
Default My first manifold (2jz, no ****!)
First time ever building a manifold, and i think it turned out really well. T6 manifold, built to fit a gt47-88mm turbo in my mk3 supra:
Tacked in place and ready for welding:
Mocked in the car:
Routing the dual wastegates and downpipe:
Just have one more gate to route and have it welded up!
RYan
Old Oct 4, 2009 | 03:26 PM
kings_blend's Avatar
Default Re: My first manifold (2jz, no ****!)
Looks good! My first was a twin scroll for my 2jzge powered 240sx. But Im only using a 72mm turbo!
What are you using in place of the distributor? I welded a bracket on the head for a gte cam sensor with gte cams and also a gte oil pump with the crank cog and sensor. Its basically a gte motor now.
Old Oct 4, 2009 | 03:37 PM
Janz99's Avatar
I am using a hall sensor with magnets machined into the back of my adjustable cam gears. A few ppl are using this setup and seems to be working pretty well.
Ryan
Old Oct 4, 2009 | 04:37 PM
snootworks's Avatar
Looks nice man!
Old Oct 4, 2009 | 04:46 PM
turbociv910's Avatar
Ryan
A buddy of mine is looking for something like that, hes gota NA-t and is having ignition issues.. More info please!!
Old Oct 4, 2009 | 06:30 PM
Janz99's Avatar
Shoot me a PM, ill see if i can dig up all the info for you.
Old Oct 5, 2009 | 04:28 AM
Karl Buchka's Avatar
Why single scroll?
Old Oct 5, 2009 | 08:48 AM
russianvr4's Avatar
OG Fabricator
Originally Posted by Karl Buchka
Why single scroll?
turbos that size most come with single scroll housings, twin scrolls are nearly impossible to find(read, custom)
badass looking manifold!
Old Oct 5, 2009 | 09:40 AM
Unseen Racer's Avatar
looks good.
but thats one hell of a turbo
Old Oct 5, 2009 | 01:32 PM
Ryan
This was my first choice but I ended up doing the other method a lot cheaper. Ive seen the magnet in the cam gear on alot of na-t's and they work like a charm. Good luck with the build!
Old Oct 5, 2009 | 03:12 PM
speeddave's Avatar
looks sick, is that a th400 on the motor?
Old Oct 6, 2009 | 01:42 PM
Janz99's Avatar
I think in the picture it was a powerglide attached to the engine. I ended up trading it for a th400 that ill be using instead. Thanks for all the compliments! I really like how it has turned out so far!
Ryan
HybridKOOP
Dec 7, 2007 08:36 AM
IMPACT
Nov 17, 2005 10:18 AM
