Tachometer going backwards need help???
Old Oct 3, 2009 | 10:06 PM
90HondaCRXSi's Avatar
Default Tachometer going backwards need help???
I was jump starting my crx because it wouldn't start up after sitting for awhile and when it finally started up the tachometer needle got stuck past redline. As i was trying to jump it i was pressing on the gas peddle to give it some juice and then it started up and the needle is now always under redline instead of on the left side. Now when i drive the car it will actually go backwards in rpm. What happened and how do i fix it?
Old Oct 3, 2009 | 10:15 PM
Radim's Avatar
Default Re: Tachometer going backwards need help???
It's JDM leave it like that...
Take out the cluster remove the plastic cover and carefully spin the needle to 0, if all else fails, buy a new cluster.
Old Oct 4, 2009 | 10:52 AM
I was driving today and it randomly jumped back to normal but idles at 0 now but thanks for the advice
2KEXVtec
May 20, 2012 03:23 PM
CapnKrunch
Dec 11, 2007 09:09 PM
Random.Hero
Sep 7, 2007 02:02 PM
type_racerz
Sep 9, 2002 05:40 PM
