Custom Cages
I've been trying to search if there is a thread for posting cages members have built and haven't came across one. Sorry if there is one and if so this can be deleted.
I'm gonna be starting a cage soon once I figure out what dimensions I'm gonna be doing so it is safe. My welds are all strong and dependable so that won't be an issue.
Does anyone have pics of cages they built?
Yeah, I need to look up the rules and guidelines. I think I read somewhere that they specifically want only mig or tig welds.
It's mostly daily driven so I have to check my clearances to see if it'd be safe for a full cage or not. I'm still learning about designing them but may end up doing something along the lines of this if my head would be too close for a full
It'll probably come down to no cage but that 8 point design would be more of a roll bar than a cage I'd suspect? I don't see much danger with that and it would still add comfort knowing I have something just in case
I built my cage according to FIA Group N regulations. They're clear, concise, and easy to understand. I don't intend on rallying the car, but I figure they're as well informed as anyone when it comes to cage design.
For a street car, don't go more than a 6-point. You don't want bars above your head if you are ever in the car without a helmet.
You can still do quite a bit with 6 points. Do a basic 4 point with a diagonal in the main hoop, then run two bars forward to tie the roll bar into the front of the car. This help with chassis stiffness.
I think the d bars are fine either way. Its all about how you read the rule book i guess. I have mine going to 6x6 plates on each side of the exhaust tunnel thingy. It just got certed a few months back.
I'm curious why you hooked the door bars like that. As it stands now they won't do much of anything, in terms of safety or chassis stiffening.
here's the rule... this is from the NHRA's rule change preview from 2008 and from what i remember as i dont have the rulebook in front of me; it reads more or less the same.
Originally Posted by NHRA technical services
“D” bar installation for full-bodied cars: For front-wheel-drive cars, with complete OEM floor (from the firewall to the rear of the trunk) and rocker/sill boxes, the 1 1/4-inch x .058-inch CM (.118-inch MS) “D” bars (when required; i.e., when the main hoop is not welded to the frame) may be welded to a 1 5/8-inch x .083-inch CM (.118-inch MS) crossmember welded to the rocker/sill box via conventional 6-inch x 6-inch x 1/8-inch-thick plates. For rear-wheel-drive cars, with neither a frame nor subframe connectors, but with complete OEM floor (from the firewall to the rear of the trunk; exception: the rear inner wheelwells may be tubbed with steel or aluminum) and rocker/sill boxes, the 1 1/4-inch x .058-inch CM (.118-inch MS) “D” bars may be welded to conventional 6-inch x 6-inch x 1/8-inch plates attached to the driveshaft tunnel."
If you'd like to see some cages check them out on my website! go in to the fabrication gallery and click on cages or you can do a search for posts iv made with differant cages.
