CODE 8 CODE 17 ???
Old Oct 3, 2009 | 04:38 PM
DOUBTS.72's Avatar
Icon2 CODE 8 CODE 17 ???
i have a 1989.Honda civic hatch 5 speed .Ed.6
Correct
me if im wrong but for CODE 8. is a new distributor rite???or new DTC,but from my knowledge DTC are not sold separately .. rite?
Any (Diagrams) of where the speed sensor is located at?FOR A CODE:17?
Notice: one thing My Speedo cable is not pluged into my cluster, do to the fact that it snapped when dropping in a new tranny.question is will this have anything to do with a (CODE:17)
Any useful help is Welcome thank you.
Old Oct 3, 2009 | 06:06 PM
Bunger's Avatar
Default Re: CODE 8 CODE 17 ???
Your speedo cable needs to be plugged in or it will toss code 17.
Code 8 probably means a new dizzy, unless you just changed some wiring?
Old Oct 3, 2009 | 07:10 PM
DOUBTS.72's Avatar
cool I Understand why Code 17 come up Now.
,but i guess Code 8 is still unresolved, since the only changes that i did was All New :tranny,clutch,(front)brakepads,clutch cable. Can you define "dizzy," based on my situation ?
Thanx.
Old Oct 3, 2009 | 07:20 PM
Bunger's Avatar
Dizzy is slang for distributor. I would resolve code 17 and reset the ECU, see if code 8 comes back. Make sure all your grounds are hooked up and tight also!!!
90RENOsedan's Avatar
dizzy=distributor.
Old Oct 3, 2009 | 10:17 PM
DOUBTS.72's Avatar
Originally Posted by 90RENOsedan
dizzy=distributor.
cool thanx Cool ride man
Old Oct 3, 2009 | 10:33 PM
DOUBTS.72's Avatar
ok cool , so i checked it out today, and one of the spark plug cables that goes to the Dizzy (<--lol) i think # 4 had the input pushed back, meaning that it did not go into the out put ,which caused my #4 spark plug ,with no SPARK really pizzed me off tomorrow i will go NGK on SPARK PLUG CABLES AND SPARK PLUGS ?will take any other suggestions For the sparks and plugs ???. Other than that i guess what im trying to do, is to not sped to much cash (i am a student ), by buying the DIZZY .i think that maybe it was just the messed up spark plug cable that SET OFF A FALSE Alarm to the ecu . maybe Correct me if im wrong .thanx for the help .
Old Oct 3, 2009 | 10:39 PM
ryanevansoh's Avatar
i would go first chose with oem spark plug wires and ngk second. and i would reset the ecu and see if it still throws the code
Old Oct 3, 2009 | 10:50 PM
DOUBTS.72's Avatar
Ok. i will trust you bro and go with oem thanx.
can you give me a quick review on how to restart it ?or should i look under FAQ?
Old Oct 3, 2009 | 10:52 PM
to reset it just pull the ecu fuse from the engine bay fuse box for like 10 seconds then re install it and start it
Old Oct 3, 2009 | 10:57 PM
DOUBTS.72's Avatar
ok cool thanx bro will do it asap tomorrow just really want that check engine light!gone!!!!!ha! suxs!
Old Oct 3, 2009 | 11:02 PM
haha i know man, i keep throwing a code 9 and ive been working on trying to get it to go away
Old Oct 3, 2009 | 11:11 PM
DOUBTS.72's Avatar
lol reason why i love civics they always keep you busy and happy, yeah they are something special hahah! good luck with Code 9 bro
Old Oct 3, 2009 | 11:13 PM
ha thanks. let us know if your code still appears
Old Oct 3, 2009 | 11:17 PM
DOUBTS.72's Avatar
fosho ill let you guys know asap. later
Old Oct 4, 2009 | 09:49 PM
DOUBTS.72's Avatar
Ok. Code 8 is gone fixed my spark plug wires, code 8 is no more! Code 17 still shows up do to the fact that i ran out of time to connect the speedo in to the cluster, but will be taken care of. ....Lesson learned from this, Code:8 can be set off by a messed up wire so first check your wires are good on both sides and restart Ecu ,and if code 8 lights up again, then that means is a for sure new dizzy. thanx all to everyone that helped
tdbaas
Apr 21, 2017 09:11 AM
Josh89SIR
Nov 6, 2007 07:29 AM
drewboy
May 14, 2005 10:03 PM
