97 hatch converted to obd1 d15b bottom end z6 head Wont start
Well i just finished putting this motor in.Its a d15b bottom end with a z6 head . Im using a 97 dx harness so i believe all the plugs wont plug into the sockets on the z6 head. I have a couple of questions
The car will crank but will not start I lined up the timing belt spun it around a couple times and it was lined up then put the crank pulley back on. When crank the car i can hear the starter going and occasionly ill hear a putt putt coming out of the exhaust i put a new cap and rotor on it and a bought a used distributor. The car is running off a stock p28 ecu.
I dont know what intake manifold this is but it looks like a y8 but isnt cause some of the plugs dont fit . There is some sort of vacuum housing with a plug and 2 vacumm hose lines I believe one goes to the pcv valve and the other goes where?
still nothing i dont know whats going on its making a popping some while trying to crank checked the timing 2 and redid it check still nothing wont fire up only crank.
just a thought... what cam gear are you using? i'm pretty sure you need to use either an adjustable gear or a y7/y8 gear to adjust for the d15 block being shorter than the z6... that might be why it's not starting.
also, are you throwing any codes?
its converted to obd1 so i dont know. Im using the stock z6 cam gear. The kid had a vx head on this d15b before this so i dont know if you need that y7 cam gear or y8. When im cranking it theres some nice flames coming out the exhaust. I brought the 1 clyinder up to tdc and lined up the cam gear. Theres a block guard in this motor would that affect anything?
fuel pump primes im getting spark out at all four clyinders .I believe the idle air control vavle isnt hooked up its a black box with 2 fittings one on each side i used off my dx motor .Where does this peice connect to both sides? Could that affect anything. I just bolted up my headlight harness i could that didnt affect anything. There was a couple of grounds on that.
I just got done converting my 96 hatch to obd1. You will need to convert your IACV to obd1 style. Everything else is plug and play. I am also using a obd2 to obd1 distributor harness. Hope that helps you out.
Here's a link that shows you how to convert your IACV to obd1:
http://www.ff-squad.com/technet
Just scroll down to the ECU/wiring tech section.
UniqueX707
18
Mar 3, 2013 05:32 PM
sonson6
May 10, 2009 03:59 PM
cloudconnected85
Mar 11, 2009 09:05 PM
leighton1245
Feb 22, 2008 07:18 PM
shauniewalnuts
Jun 27, 2005 08:20 PM
