89 crx zc 1.6l dohc non vtec starts hard
Check you're vacuum lines. It might of slipped off or it might be damaged. You might have uncontrolled air entering the manifold. When did this start?
when i swapped the stock 1.5 out and put the zc dohc. but when it warms up it runs fine besides the high idle. but sometimes it wont start period, and u let it set for like 10 15 minutes it starts right up
Man i have the same problem i have a d15 with dual port. mine also sometimes wont start. i have been trying to find a vacume leak but its hard to find it while the motor is idleing. does anyone know how to find a leak?
spray a mist of water on your vac lines, if the engine bogs you've found the leak.
The Main Relay is a common reason for the EF's not to start.
Hey guys. I swapped a 1.6 DOHC ZC into my crx and i have spark and fuel but it wont start. it turns over and sounds like it wants to start but doesnt. also I have a full parts list for the ZC DOHC motor if you need it
theredegg
Mar 30, 2009 03:21 PM
h22_crx
Jan 26, 2008 05:06 AM
