Headgasket info
Replacing the Head Gasket on my 1.6 and i heard that you have to take off the block bolts in a special pattern. If so what pattern? Also when taking off the old gasket i also heard that using a razor blade is bad. And i dont have much crazy usefully tools. Whats a good tool to use for the headgasket?
tyty
tyty
you take off the bolts starting with the two middle ones and work your way outwards on both sides. also make sure you label the bolts and put them back in the hole you took them out of.
http://www.youtube.com/watch?v=2lM7I...layer_embedded
torque specs:
https://honda-tech.com/forums/showth...t=torque+specs
torque specs:
tremor86
Jul 3, 2004 03:14 PM
