injector question for my 99 gsr
Old Oct 2, 2009 | 06:48 PM
lsturbo00's Avatar
Default injector question for my 99 gsr
Hey guys i just bought an integra a couple weeks ago, it didnt pass smog because the turbo9(FULL TURBONETICS KIT 4 SALE $1700 W/O FUEL MANAGEMENT) , so it took the kit off and am trying to put it back to stock. The injectors that are in the car at 310cc injectors, I am getting a CEL code being too rich or too lean. So I wanted to buy some stock injectors. My question was will the obd 1 injector work on my 99 gsr? If i just obd1 injectors do i need a resistor box? or should I just get the obd 2 injectors?
Thanks
Rob
Old Oct 2, 2009 | 09:35 PM
95dc2teg's Avatar
Default Re: injector question for my 99 gsr
Thanks
Rob
What brand injectors do u have in there now. If the 310cc injectors are RC's the injector clips were most likely swapped out for obd1 clips, so you would have to get obd1 stock injectors. You wont need a resistor box. The only difference between obd1 and obd2 injectors are they clips that go into them. Any stock obd1 injectors from a ls/gsr/ or I believe even a civic would work as they are all 240cc. Are you using a stock ecu with the 310cc injectors? if so thats why your car is running like poo.
Old Oct 2, 2009 | 09:43 PM
lsturbo00's Avatar
Hey thanks for the info, I am going to go on a hunt for some injectors to get this thing back to stock. I did just put back the stock ecu, and Now i have a CEL45 that should get fixed after putting the stock ones in.....
Old Oct 2, 2009 | 09:57 PM
95dc2teg's Avatar
Yes it definitely should. Your stock ecu doesnt know the difference between the injectors size and thinks u are running 240cc. It opens them and closes your 310cc injectors the same duration as if it would if they were the stock 240 so your car is receiving way too much fuel with the 310cc.
Old Oct 4, 2009 | 03:49 PM
lsturbo00's Avatar
thanks for the help guys, I found some stock injectors, it works fine with out any CEL!!!! the next thing is the SRS light!!!!
Cap'N Chronic
15
Mar 9, 2011 11:45 AM
SHystrdyGSRtdy
Feb 8, 2005 01:40 PM
goldffronts
Jan 30, 2003 05:12 PM
