Bad tensionor or maybe warped cams?
Old Oct 2, 2009 | 02:05 PM
aaron_ex's Avatar
Default Bad tensionor or maybe warped cams?
I have a 91 acura integra with crower 404s and crower dual valve springs/retainers. I put the motor together drove it maybe 10 minutes and it jumped timing at a low rpm. It does not have any bent valves, but i went to run it today and it did the same thing. I put a new timing belt on but did not change the tensionor. Obviously with the timing belt being loose after jumping timing i assumed it was the tensionor. Im replacing it tomorrow i just want to get some imput of other possibilities of what could cause this before i chance bending a valve.
Old Oct 2, 2009 | 06:01 PM
aaron_ex's Avatar
Default Re: Bad tensionor or maybe warped cams?
bump, i know someone can help me.
Old Oct 2, 2009 | 06:39 PM
Dogginator's Avatar
Daisy... Daisy...
Improperly set tension is the culprit. Also, check the cam gears for tightness.
Old Oct 2, 2009 | 06:48 PM
aaron_ex's Avatar
how should it be set, we stated to tighten it, moved the pulled a tiny bit (to set the tension) then tightned the pulley. The tensionor still holds some tension when i pulled the tbelt off, but its done it twice. It keeps moving. I doubt the bolts not tight enough.
Old Oct 2, 2009 | 06:52 PM
Dogginator's Avatar
Daisy... Daisy...
You turn the crank CCW three teeth with the tensioner loose and then tighten the bolt. The belt should only deflect about an inch if it is tight enough.
Old Oct 2, 2009 | 06:55 PM
aaron_ex's Avatar
yup thats how it was. I have done many timing belt jobs that way, never a issue.
Old Oct 2, 2009 | 07:15 PM
aaron_ex's Avatar
It will stay tight, run it, check it still be tight. Its when it gets revved up into the high rpms its like it slow loosens. Basically, is this a sign of a bad tensioner?
Old Oct 2, 2009 | 07:49 PM
Dogginator's Avatar
Daisy... Daisy...
The tensioner bolt is slipping or it is physically damaged.
Old Oct 3, 2009 | 01:50 AM
95DC2GS-R's Avatar
Sounds to me like the tensionor wasn't torqued down enough... could also be the spring.
Old Oct 3, 2009 | 03:27 AM
aaron_ex's Avatar
does not look like the bolt is spinning. Just like the tensionor is slowly moving and cause the belt to become looser and looser.
the spring would not tighten the belt enough to i put something under the tensionar to get the belt tight then tightned the tensionor untill i could not anymore.
stagen
Dec 21, 2008 07:31 AM
mr_magoo
Aug 23, 2008 12:41 AM
90si_mugen_crx
Jul 25, 2005 03:09 PM
tegasaurus
Oct 28, 2003 08:15 PM
Fooser
Apr 26, 2002 07:55 AM
