Suspension & Brakes Theory, alignment, spring rates....
buddy club N+spec damper vs Koni/groun control
Old Oct 2, 2009 | 12:24 PM
leochilo's Avatar
Icon3 buddy club N+spec damper vs Koni/groun control
ive been saving up money for a suspension upgrade. and from what i had seen in here, everybody gives props to the koni's with the ground control coilovers. and a guy from pann auto in sandiego recomend me the buddyclub suspension,, because it was cheaper and it was good for a dd basis. i just want to have my car drop and have it smooth as possible for a daily driven basis... what do you guys recomend me..
Old Oct 2, 2009 | 12:43 PM
jason.az1's Avatar
Default Re: buddy club N+spec damper vs Koni/groun control
I have buddy club race spec
and they can slam your car and ride awsome
at the same time. Best suspension I've ridden in
I know GC w/ tophats can slam the **** out your car but I dont know about ride
Old Oct 2, 2009 | 01:05 PM
leochilo's Avatar
[QUOTE=jason.az1;40158715]I have buddy club race spec
what about the N+spec damper do you have info on those??
Old Oct 2, 2009 | 08:04 PM
STOCK_SOHC_DX's Avatar
I just sold the N Spec+ to buy Koni's. The ride sucks *** compared to Koni/GC.
Old Oct 5, 2009 | 10:40 AM
leochilo's Avatar
anybody else had thesse.??
Old Oct 8, 2009 | 04:59 AM
.Manny.'s Avatar
Touching My Member
I've driven a couple of cars with the N+ set up. They both rode horribly. they both bounced way too much. go with the koni/gc for sure. Do some searches on which spring rate you should run, what you want from the ride is important when doing this.
Old Oct 8, 2009 | 09:49 AM
Andy@AMR's Avatar
The N+ is not a setup I would recommend for a DD. It's pretty harsh, and the dampers are valved for higher spring rates.
Old Oct 8, 2009 | 12:56 PM
racebum's Avatar
did we ever get around to figuring out what "ride" was around here?
Old Oct 8, 2009 | 01:14 PM
importdude2000's Avatar
go with the RSD
Old Oct 8, 2009 | 06:43 PM
Not smooth or bouncy is my definition. Pretty much the shocks were valved for some ridiculous spring rates then what the came with.
Old Oct 9, 2009 | 09:51 AM
leochilo's Avatar
ok it seems ima go with the GC/KY.. now what spring rate you guys recommend me for my 98 ek hatch ,rite now it has a single cam but im planning to drop a b series in there.
what spring rate i should get,, i want to be slammed and do a couple of circuit races..
Old Oct 9, 2009 | 10:53 AM
blaze the chemi's Avatar
Just remember to set the dampening control when you are testing them. I have 400f/450r with damp control about 60% in front and about 75% in rear. If I recall it takes 16 'marks' on the adjustment **** to go from full soft to full stiff. Use a nut for reference while turning.
The Koni/GC setup is much better than the KYB/GC I have previously. Slightly different rates, but the shocks make one hell of a difference.
Old Oct 9, 2009 | 06:38 PM
Honda Rules's Avatar
Dont mean to thread jack, dont really feel like making a quick ? thread so...
When you adjust the Koni sports, can the suspension be compressed or does it have to be in the air, full droop?
Old Oct 9, 2009 | 07:55 PM
racebum's Avatar
there are no marks or clicks on konis
Old Oct 12, 2009 | 06:32 AM
When you adjust the shock (Koni Sports) they can be adjusted anytime because the adjustment is at the top of the shock.
Not on the shock....I'm talking about the white **** used to turn the adjustment. The **** has little bumps on it and I use those bumps from either full stiff or full soft to determine where I am at in the spectrum. I use a bolt in the background as a reference for my eyes.
Old Oct 14, 2009 | 02:40 PM
a97b18b's Avatar
I bought BC N+ Spec probably back in june or july. I haven't installed them yet but i just hope they're not as bad as you guys are making them out to be
Old Oct 14, 2009 | 03:18 PM
momoEG9's Avatar
i love the koni/gc been drive it for year .. i have a extra set iam try to let go only for 450 obo ... it ride very smooth .. u can slam ur car low .. and drifth it all the way . one of the best shock and spring ..
Old Oct 14, 2009 | 05:52 PM
DrZFiNeSt's Avatar
I had the N+ on my ep and wasn't happy.Rode a tad bit on the stiff side.Gonna go with koni/GC and see what happens
Old Oct 15, 2009 | 07:04 PM
Night and day difference!
SpeedRacerEX-R
Apr 10, 2006 02:16 PM
turbow
Apr 11, 2005 09:04 AM
yellowturbo
Dec 27, 2004 10:25 AM
Ricey McRicerton
Jun 17, 2002 10:12 AM
