b series power steering pump
Old Oct 2, 2009 | 10:34 AM
shogee's Avatar
Default b series power steering pump
i just did a swap into my 99 coupe, swapped in a jdm b16a, used to have a d16y8. now i want to run a power steering pump and my question is, is all b series power steering pumps the same. i pulled the motor out of a 94 integra with the pump and every thing. i already tried switching out the d series with the b series, but the high pressure hose connection to the pump is different. im just curious as to what other people have done. thanks
Old Oct 2, 2009 | 10:37 AM
Weifast's Avatar
Default Re: b series power steering pump
I used an 01 ITR ps pump with all my other components coming from a b16a2. Most or all b-series pumps are the same (at least I know for sure the GSR, Si, and ITR pumps are the same. I'm not sure if the LS uses the same pump or not, but I'm sure it is).
Old Oct 2, 2009 | 10:59 AM
shoklid's Avatar
all b series blocks run the same stuff all interchangeable with the exception of head stuff and wiring . u can use the pump out of any b
shoklid's Avatar
maybe a lil diff between obd1 and obd 2 but not to sure
Old Oct 7, 2009 | 04:42 AM
shogee's Avatar
thanks i just wanted to have someone else kinda confirm it
Old Oct 7, 2009 | 06:24 AM
hmoobhero's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-retaining-power-steering-ek-b-series-swap-1822781/
BAM!!! search is a wonderful thing buddy! you're welcome!
gemballla
Jun 4, 2010 01:49 PM
roger93si
Nov 16, 2007 04:58 PM
smash fascism
Oct 4, 2005 03:45 PM
Danal976
Feb 8, 2005 02:08 PM
shadykit
Jun 3, 2004 12:58 PM
