CEL wont light up
Old Oct 2, 2009 | 09:41 AM
JDMGhosteg-6's Avatar
Default CEL wont light up
I have searched and found nothing. I just swaped LS motor into my 95 Civic Coupe. Everthing is connected and I am useing the LS ECU. WHen I go to start the car I have no CEL and no fuel pump purge. I tried to pull the codes manually but the plug next to the ecu and nothing happens. I also checked all fuses and the CEL bulb everthing is ok. Can anybody tell me what else I should check for. Thanks
Old Oct 2, 2009 | 09:45 AM
Amed Irizarry's Avatar
Default Re: CEL wont light up
Make Sure That You Got Good Ground. And Check Your Thermostat Housing For That Ground Wire.
Old Oct 2, 2009 | 11:03 AM
shoklid's Avatar
what yr is the ls from
Old Oct 2, 2009 | 12:53 PM
I will double check all grounds. Motor is 94
Old Oct 3, 2009 | 02:32 PM
thanks it was my Ground!!
GrabbingGears93
85
May 9, 2016 08:06 PM
bowdown201
Apr 29, 2009 07:21 AM
forcefed22
Sep 18, 2008 08:18 PM
BOOSTEDgreeneg
Sep 15, 2005 07:27 PM
95LSS
Mar 7, 2004 11:00 AM
