Skunk 2 troubles....
Old Oct 2, 2009 | 04:49 AM
greenzchatch's Avatar
Default Skunk 2 troubles....
I'm going to make this as short and as possible
My setup: 90 civic lx sedan, Skunk2 Pro-s coilover setup( coilovers + shocks) Skunk 2 front camber kit. wheels 15X8 equips +10 offset
Ok, so I want to keep the car as low as it sits now and still be able to tuck these wheels under the fender wells. I installed the front camber kit and adjusted it as negatively as possible but for some reason it actually RAISED the front end of my car about .5"-1.0" and now I hear this knocking noise comming from the front whenever I drive, and the front suspension feels extremely tight! All I did was put the camber kit on WTF!!! Can somebody tell me what I did wrong or if there are any solutions so that I can keep my car slammed and still tuck these wheels underneath....Any help will be greatly appreciated!
Old Oct 2, 2009 | 05:05 AM
Furyof4's Avatar
Default Re: Skunk 2 troubles....
The skunk balljoints are taller than stock. You must be running so low that you had near zero clearance with the stock balljoint(WAAAY too low). In which case the ball joints are hitting the shock towers now. Only solutions, remove camber kit or raise car.
Old Oct 2, 2009 | 06:34 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Which camber kit did you use, the control arms?
If you didn't use the control arms then look with a flashlight and you will see your upper control arms are hitting the pinch weld.
If you did use the control arms (I doubt it) then something is wrong. Skunk2 control arms are the same as stock but more rigid and the movable ball joint is only 1/4" or so taller; I have a hard time believing it is hitting the upper wheel well.
The symptoms you describe is almost always from the upper control arm resting on the pinch weld; this leads your car to not actually going all the way down.
Old Oct 2, 2009 | 07:00 AM
Furyof4's Avatar
Someone else measured it for me and it was more like 3/4" taller. I had the same thing happen to me with the spc adj. balljoints and I wasn't anywhere near as low as the OP. I had pretty soft springs at the time though which didn't help the situation.
Old Oct 2, 2009 | 08:01 AM
Dammit I was afraid of that, but the car actually isn't that low I dont think, well I'll take pics and post em up so you can see...
That's the thing, I did use the skunk 2 control arms. That's why I can't figure out WHY I'm having these problems. I'll be sure to post pics...
Thanks fellas! I'll make sure I take some pics for yall so you can see some things too!
Old Oct 2, 2009 | 08:21 AM
Furyof4's Avatar
That's really low.
Old Oct 5, 2009 | 05:20 PM
Well I'm sorry it took so long but here's some pics...
Here's how the car sits now, yes I know it's to low in the rear but the front is what I'm worried about now...
the kit
Installed...
and here's the height in the front...
I hate to admit it but I think my A-arms are hitting
Old Oct 5, 2009 | 05:44 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Your assumption is correct you are probably hitting your a-arms.
EP-tree
13
Nov 26, 2009 12:10 PM
greenzchatch
Suspension & Brakes
Oct 5, 2009 05:19 PM
markysparky
Suspension & Brakes
Feb 2, 2006 04:15 PM
Spectrum24x
Aug 12, 2005 11:59 AM
Superdragr45
Feb 6, 2003 02:27 PM
