1991 Honda CRX HF**JDM B18C**LSD,Koni,Tanabe,Skunk2!New pics! 4,500$!
Old Oct 1, 2009 | 09:14 PM
TOUGE4LIFE's Avatar
NO LEGS
Default 1991 Honda CRX HF**JDM B18C**LSD,Koni,Tanabe,Skunk2!New pics! 4,500$!
Final Price: 4,500$
This car is easily One of the Fastest, Most reliable, Best MPG (mid to high 30's) cars you are going to get for 4,500$ The car is built with the best of the best, and it shows.
Car: 1991 Honda CRX HF Rio Red with black interior 74,000 Miles on the body!! Far less on the Swap from Hmotorsonline with receipts(4,300$ just for the motor and transmission)!!
Price: 4500 or Trade. Pretty firm on price.
Engine Bay:
Full Legit JDM GSR swap from Hmotorsonline with receipts, roughly estimating 45,000 miles on the motor and transmission (LSD GSR Trans). OBD0 to OBD1 converted with Rywire conversion. Compression Test recently done reads 230 across the board.
Hasport Motor Mounts
Hasport Cable to Hydro conversion
VPT shift linkage
Exedy stage 1 Clutch
Fidanza lightweight flywheel
1st gen Skunk 2 intake manifold
AEM Cold Air intake
65mm Throttle body
Tanabe Touring medallion Cat-back exhaust
Si fuel pump
Battery Relocation in the hatch
Suspension/Brakes/Wheels:
Koni Yellow adjustable shocks
Tein S-tech Lowering Springs
Integra GSR front brake conversion
Hawk HP+ Brake Pads
Russell Stainless Steel Brake lines
15inch Rota Autoxs
205/50/15 Falken Azenis
+ Much More, Mostly smaller items
Maintenance: Oil is changed within every 2,000 miles with Mobil oil and filter (Seems excessive but you can never be too safe). Timing belt, Tensioner, and Water Pump were all replaced within the past 3,000 miles.Last weekend I upgraded to a bigger Si fuel pump and I replaced the fuel filter. The entire front end has been replaced with new inner and outer tie rods, sway bar ends, and upper control arms. The car throws NO check engine lights, and does not leak or burn oil.
Overall the CRX runs great pulls strong, and makes for an awesome driver(averages 36mpg no joke) . The suspension setup makes for an extremely versatile ride that can be adjusted for any type of pavement.With a simple turn of a **** you can adjust the stiffness of the ride, from race car mode to cadillac smooth with just a simple turn. The car looks good for its age, and is complimented often for its looks and refined tone.
The few downsides to the car would have to be that the body is good, but not perfect for its age. It does have minor rust, some faded paint (roof/ lightly passenger side), and misc door dings. There is no climate control installed in the car, but will be included if sent to a new home.Everything is there still, the control unit itself is just not installed. The set of Rotas need tires. The set of steelies are great. I just returned from vacation and came home to my car having a 3 inch crack going across the passanger side of the windesheild.
Contact me @ 715-281-9322 or Email touge4life@hotmail.com I have Tons of pictures just email me.
Click the links below, all the linked pictures show every defect of the car. I Don't want anyone comming to look at the car and being disipointed, I have been there sooo many times and know how frustrating it is to spend the time to look at a "perfect car" and when you get there its not perfect. I am not here to waste anyones time, if you want a honda thats fast, reliable, gets good MPGs, and is built with the best of the best than this is the car for you
Again, the Price is 4500$ this is about as low as I will go. The receipts from Hmotors online total 4,300$ and thats just for the motor/tranny. Feel free to give me a call and we can work something out. Thanks for looking.
http://i537.photobucket.com/albums/f...R/IMG_3696.jpg
http://i537.photobucket.com/albums/f...R/IMG_3697.jpg
http://i537.photobucket.com/albums/f...R/IMG_3699.jpg
http://i537.photobucket.com/albums/f...R/IMG_3700.jpg
http://i537.photobucket.com/albums/f...R/IMG_3701.jpg
http://i537.photobucket.com/albums/f...R/IMG_3702.jpg
http://i537.photobucket.com/albums/f...R/IMG_3703.jpg
http://i537.photobucket.com/albums/f...R/IMG_3704.jpg
http://i537.photobucket.com/albums/f...R/IMG_3705.jpg
http://i537.photobucket.com/albums/f...R/IMG_3706.jpg
http://i537.photobucket.com/albums/f...R/IMG_3707.jpg
Old Ride Height
Old Oct 1, 2009 | 09:36 PM
austena123's Avatar
Default Re: 1991 Honda CRX HF**JDM B18C**LSD,Koni,Tanabe,Skunk2!New pics! 4,500$!
whats it run? bump...
Old Oct 1, 2009 | 09:43 PM
FLYBOIR's Avatar
bumpppp
Old Oct 2, 2009 | 06:39 AM
TOUGE4LIFE's Avatar
NO LEGS
I would guess it is near the 14.0 second range or faster. Again thats just a guess.
Old Oct 2, 2009 | 06:42 AM
BOOSTED EG6's Avatar
bump
Old Oct 2, 2009 | 06:43 AM
Rtboy10's Avatar
clean swap and nice car
Old Oct 2, 2009 | 07:38 AM
TOUGE4LIFE's Avatar
NO LEGS
Low mileage, Hard to find an HF with mileage like this.
Old Oct 2, 2009 | 10:42 AM
TOUGE4LIFE's Avatar
NO LEGS
Thanks. No hack jobs on the swap.
Old Oct 2, 2009 | 10:43 AM
Fantastic420's Avatar
I want the damn wheels!!
Old Oct 2, 2009 | 03:17 PM
TOUGE4LIFE's Avatar
NO LEGS
The can be yours for the small price of 4,500$. I'll even throw in a CRX with them for that price.
Old Oct 2, 2009 | 05:24 PM
.:::I'm Fantastic:::.'s Avatar
Dude are you a little person like Zach Roloff?
mint *** ride
Old Oct 3, 2009 | 09:57 AM
TOUGE4LIFE's Avatar
NO LEGS
mint *** ride
I don't know zach roloff, but yep Im 3ft 9in tall. The pedal extensions can be taken off and moved to another car within 5 mins.
Old Oct 3, 2009 | 12:44 PM
JJtegfan14's Avatar
trade for a built b16 del sol?
Old Oct 3, 2009 | 02:54 PM
0ne-Cam's Avatar
Trade for a built b18 ef hatch? check the build thread, build is on the verge of being finished with fresh paintjob
Old Oct 3, 2009 | 03:56 PM
TOUGE4LIFE's Avatar
NO LEGS
Interested, let me know when its done.
Old Oct 3, 2009 | 03:57 PM
TOUGE4LIFE's Avatar
NO LEGS
Send me some info.
Old Oct 3, 2009 | 04:15 PM
If I was to trade/sell a clean/built car like that rex. I would most def. fix up that little rust. Nice car mane, good luck with sale.
Old Oct 3, 2009 | 04:24 PM
Fibercation's Avatar
love the car
Old Oct 3, 2009 | 04:39 PM
JJtegfan14's Avatar
HERE SHE IS
http://hondamarketplace.com/showthread.php?t=2649694
Old Oct 3, 2009 | 10:40 PM
TOUGE4LIFE's Avatar
NO LEGS
Let me know if you are willing to trade straight up, no cash on top, with all your parts included. My car runs and drives great, I would trust it anywhere. You car is needing some work, so I feel a straight trade + the parts it takes to fix your car is an even deal.
Old Oct 4, 2009 | 08:39 AM
TOUGE4LIFE's Avatar
NO LEGS
Originally Posted by Fibercation
love the car
Thanks.
Old Oct 4, 2009 | 06:14 PM
TOUGE4LIFE's Avatar
NO LEGS
TTT
Old Oct 5, 2009 | 03:01 PM
TOUGE4LIFE's Avatar
NO LEGS
Up again.
Old Oct 11, 2009 | 03:20 PM
TOUGE4LIFE's Avatar
NO LEGS
SOLD! SOLD! SOLD!
Old Oct 11, 2009 | 05:30 PM
JDM_Frijoles's Avatar
mint *** ride
Wow, that wasn't ignorant Should come at this guy with a little more respect instead of calling him out like that. I didn't notice the extension pedals till you mentioned it.
Bump for a mint *** CRX.
