too stiff shocks?
Old Oct 1, 2009 | 09:10 PM
So krazieY's Avatar
Default too stiff shocks?
I got tokico blue shock and they are too stiff for me. What shock do you guy recommend?
Thanks
Old Oct 1, 2009 | 09:23 PM
DaveSi677's Avatar
Default Re: too stiff shocks?
if you find tokico blue to stiff then anything else is going to be really to stiff unless its stock!
Old Oct 1, 2009 | 09:35 PM
eMpAtHy's Avatar
try softer springs.
Old Oct 2, 2009 | 04:23 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
if it's an RSX buy the a-spec shocks
Old Oct 2, 2009 | 06:53 AM
DaveSi677's Avatar
I should of asked this first before posting my first response but what suspension do you have right now on your car?
Old Oct 2, 2009 | 07:14 AM
mustclime's Avatar
blues are stock replacements....do you have after market soring or huge sways?
Old Oct 2, 2009 | 07:18 AM
accord_raffi's Avatar
sways wouldn't make his vertical bound any stiffer.
Old Oct 2, 2009 | 07:20 AM
alphalanos's Avatar
what kind of springs do you have. either get softer springs or deal with it. higher spring rates are needed for lowered car and to reduce body roll.
Old Oct 2, 2009 | 08:10 AM
mustclime's Avatar
Yes they do, they are in effect torsion springs. Unbolt one side of you sways some time, you will be shocked at the difference in ride down a bumpy street.
Old Oct 2, 2009 | 11:14 AM
So krazieY's Avatar
I got the tokico struts and shocks
Old Oct 2, 2009 | 05:43 PM
I think you misinterpreted www.howstuffworks.com
Old Oct 3, 2009 | 08:29 AM
mustclime's Avatar
I love smarta$$ replies with no facts to back them up.....do you really think that sways do not effect ride quality? One of the ways to test a theory is to take the theory to the limit.....
normal case.....you are driving your riced out civic down the road, you hit a 3 inch tall bump with your right tire...what happens?
1) the wheel hits the bump that forces the wheel up
2) the knuckel and lca are forced up
3) the spring is compressed
what happens to the sway that is attached to the right lca, the body in 2 places and the left lca?.....does it flex maybe? Would that flexing add to the overall spring rate of the car if you riced out civic was stiff enough to not flex?
Take the theory to the limit.....Say megan came out with a new 6 inch dia solid swaybar that they claim will make you the king of all ricers, you of course buy it......How Would your car react to a 3 inch bump with a swaybar that would work well on a 70 ton M1a2 main battle tank? Would your front suspension be independant any more? Would the ride quality be effected? What would happen is as you run over that 3 inch tall bump, the sway would not flex...at all, the lca would not move at all independant of the other lca and the whole corner of the car would be forced up....has ride quality been effected?
Don't beleive me?....pick up a cusco 25mm soild rear sway or a hotchkis 27mm hollow rear sway.....dips and speed bumps do not effect the ride with a super stiff sway as long as it effects both wheels the same amount. The sway just pivots. Ask the suspension to be independant though and you will feel a stiff sway with bumps and dips that only effect one wheel..
Old Oct 3, 2009 | 08:31 AM
kobeballer96's Avatar
^ dont mess with this guy. he knows his **** on suspension! i got h and r springs for my ep and tokico blues. but i think 2 inch drop was too much drop.
Old Oct 3, 2009 | 05:30 PM
vladd's Avatar
tokico blues are oem replacements. if that's too stiff then a lowered car isn't for you. put the stock springs back in and see if the ride gets better .
luder23
Suspension & Brakes
Dec 15, 2012 03:06 PM
g2tegsown
Jul 17, 2007 09:11 AM
charjacq
May 9, 2006 10:33 PM
wowee
Apr 17, 2004 10:40 AM
victor903
Feb 20, 2003 06:28 PM
