LS into EJ8
Old Oct 1, 2009 | 05:29 PM
morseb1's Avatar
Default LS into EJ8
my d16y8 is not putting out enough power for me so i got a good deal on a b18b1 from a 97 integra. Im sure the swaps been done loads of times but i cant find anything about it. where the d16 has vtec and the b18 doesnt will that be a problem? And what's the deal on the OBD stuff. ive just heard i need 97-01 cause its obd2 like mine or somehting. just wondering if i could get some of this cleared up and if someone could point me toward how to go about this swap. Thanks soo much to anyone that can help.
Old Oct 1, 2009 | 05:54 PM
R666_EK's Avatar
Default Re: LS into EJ8
Since the b18 does not have VTEC you just ignore that wire. You will need to find an OBD2B P75 ECU since the motor you have is OBD2a and your car is OBD2b. I'm not sure if the 00-01 LS had immobilizers or not. If they do you will have to either send it in to get it removed or find an OBD2b to OBD2a jumper harness. That would be the best route. Other than that its pretty much straight forward like any other B series swap. You NEED to use the EWH that is already in your car as it is a one piece harness and the integras are two piece.
Old Oct 1, 2009 | 05:56 PM
MoreBoost!'s Avatar
check out my thread it'll be helpful
Old Oct 1, 2009 | 06:32 PM
morseb1's Avatar
Im pretty sure that it was just 2000-2001 they had immobilizers so hopefully i wont have to worry about that, And if thats the case then does that mean all i need is the OBD2B P75 ecu and it should all go in smooth?
Old Oct 1, 2009 | 06:37 PM
R666_EK's Avatar
Yeah or a jumper harness with the OBD2a ECU
I'm pretty sure 00-01 integras were all OBD2B and the 99-00 civics were also. So if thats the case then an OBD2B ECU will have the immobilizer.
Also, not sure if you have looked into what mounts you need to get yet, or if the wiring was the only thing you were wondering about.
Old Oct 1, 2009 | 06:40 PM
morseb1's Avatar
yup got innovative mounts, wiring was the only touchy parts, thanks tons
Old Oct 1, 2009 | 06:42 PM
R666_EK's Avatar
Make sure you get a 99-00 civic SI rear L bracket and SI timing bracket.
Edit: Just noticed you have a Canadian spec SI. You want the US spec SI. Or I think its the SiR in canada. Whichever model has the b16.
Old Oct 1, 2009 | 06:47 PM
morseb1's Avatar
k, ya i have d16y8, (if i had b16 i probly wouldnt put in ls haha). does that make anything else change?
Old Oct 1, 2009 | 06:52 PM
R666_EK's Avatar
Nope. Its basically the same swap I did in my old EJ6, but easier.
You will still need to get the L bracket and timing bracket off a 99-00 B16. Also the torque mounts if you want to use em.
jmflyd
10
Apr 14, 2009 04:47 PM
2.2coupe
Oct 10, 2007 09:48 AM
93sihatchy
11
Jun 10, 2007 03:40 PM
infulleffect
Jan 31, 2006 06:56 PM
badassteg97
Jan 25, 2006 04:01 PM
