Weird problem....Need help
Old Aug 28, 2002 | 03:30 PM
sicivic's Avatar
Default Weird problem....Need help
The other night when I was driving home on the highway, my check engine light came on. While I was driving, I pulled back the carpet and I could of sworn the ECU was flashing a code 2, but I looked in my Haynes manual and there isn't a code 2. The car was fine for a few minutes. Then all of a sudden it lost power and bogged. I tried downshifting and flooring it but nothing. So I pulled over and turned the key all the way off and then tried to start the car. It started right up and ran fine. The car has been fine since then. But today it did it again, but this time the check engine light didn't come on. I turned the car off and then it started right up again. I drive a 89 Civic Si. Does anyone have any suggestions? What is causing this? Thanks in advance.
Old Aug 28, 2002 | 03:36 PM
Hondasaurs's Avatar
Default Re: Weird problem....Need help (sicivic)
Here is a list of ECU codes..maybe this will help
http://tech.hybridgarage.com/tech/codes.html
Old Aug 28, 2002 | 03:46 PM
Hondasaurs's Avatar
Default Re: Weird problem....Need help (J SPEC Si)
Its about 35 miles west of Albany. .....between albany and Utica....just a couple of miles off the thruway
Old Aug 28, 2002 | 03:57 PM
Hondasaurs's Avatar
We go out to Big Lots in Utica on wednesday nights usually, last week there were probably 100 cars or so.
Old Aug 28, 2002 | 05:26 PM
Aphrodavid's Avatar
youre correct, there is no code 2 for your make/model. code 2 is for secondary O2 sensor, which you dont have. you more than likey have an electrical problem somewhere or it could be your ECU.
Old Aug 29, 2002 | 06:29 AM
sicivic's Avatar
Default Re: Weird problem....Need help (Braveheart)
Anyone else?
Old Aug 29, 2002 | 07:26 AM
EightOhOne's Avatar
My old blazer did that too....I never did figure out what it was, I just sold it to some mexicans. Maybe its something in your fuel system
250r king
Apr 17, 2010 10:08 PM
ANONYMOUSdeecee
Mar 7, 2007 07:47 PM
compwc18
Oct 19, 2004 05:01 PM
Teggin2
Feb 18, 2004 12:04 PM
CWBETB
10
May 29, 2003 10:16 AM
