Heater in 95accord not working?
Everythinh turns on, but i get cool air? I'm a noob when it comes to cars, but i try my best to do certain things.. any idea's on what i should do to see what's the problem.. My switch works it turns and everything, but i get cool air not hot air.. Thanks
Check your heater control valve thats bolted to the firewall. Its black plastic with two hoses connected at both ends. Make sure it moves when you move the temp control inside the car. Also feel that the hoses are hot. If not hot check for a stuck open thermostat
alright I check the hose it's warm but not hot, and i see something with a lever that a spring that goes in and out, that was disconnected i connected it back, and i notice when i push the lever inwords the car gets colder even thoh the dial is on hot, and when i pull the lever to the left (towards me) no more cold air, it's warm but not hot like my heat used to be? That lever is on the heater valve what is that?
cornsnake19
Nov 28, 2017 09:11 PM
