Where is my Air conditioning sensor? Details inside
Old Oct 1, 2009 | 04:33 AM
driveslow's Avatar
Default Where is my Air conditioning sensor? Details inside
94 civic ex coupe stock d16z6
I tried searching online and could not find a pic or its location.
My car wants to stall when I come to a stop while ac is running. I have found that this is do to a bad ac conditioning sensor. Please help me locate this sensor or if this problem is something else.
Thank you.
Old Oct 1, 2009 | 05:21 AM
RyanA's Avatar
Default Re: Where is my Air conditioning sensor? Details inside
If you are talking about your pressure sensor, it is located on the filter/dryer on the driver side. Make sure your condensor fan is going. If it's not, it will hit high pressure very quickly and cause lots of problems.
Old Oct 1, 2009 | 05:28 AM
driveslow's Avatar
I believe it is the sensor that tells the ecu to go to a higher rpm when the ac is turned on. Condesor fan is definitely going.
Old Oct 1, 2009 | 05:39 PM
driveslow's Avatar
bump bump
holmesnmanny
Honda Civic (2006 - 2015)
Jun 3, 2017 02:07 PM
JohnnyEF
Jul 12, 2007 08:07 AM
1SickHb
Nov 10, 2005 01:04 PM
