clutch problems mabe??
ok just did a dohc zc swap and i put the hf trans and clutch back in and now it wont go when i try to take off it feels like the clutch is grabbing then letting go what ever it is makes a bad noise and shakes the car im thinking its the clutch but i want to kno what yall think before i buy a new one thanks
Did you just reuse the old stuff? It might be a throw out bearing, does it only make the noise when you try to take off? Does the noise stop when you just push in the clutch?
You should have just replaced throwout bearing and pilot bearing while you had the trans out, for peace of mind.
Just a thought though. Maybe someone else will chime in and give you a better idea.
no its not that i checked it before i put it in the car and and it only makes it after i start to take off it will pull for a second then make it thats what makes me think its the clutch plus i have the hf clutch on a dohc zc!
Solstic
Jun 13, 2012 11:34 AM
