what kind of power from fuel setup
I was wanting to run one bosch 044 intank and one inline is the power output potential the same as if I ran 2 intank or inline? I am trying to make a little more then 700 on e85 or the most that my stock block will handle. Its for my sc300 but that besides the point just trying to get the fuel right
thanks in advance
Sean
thanks in advance Sean
anyone know I forgot to add that I will be running id 1000cc injectors and -8 feed and -6return so what kind of power is feasible with those two pumps in that configuration anyone???
well a friend of mine runs a 044 in a boosted ls1 car and puts down almost 600 at the wheels so i dont think that you should have a problem. also its a inline and -8 feed and and -6 return. hope that helps. i know its a completely different app.
Running them in series like that will bump up the flow slightly, but nowhere near the amount of flow if they're run parallel.
You're going to need to run them in parallel for 700whp on E85.
Do it with a surge tank. Have the stock denso pump feed the tank and then run 2 044's off of that in parallel. For what it's work I recently ran into the end of a single bosch 044 on GAS at 730whp on a car. Not sure what Tony has gotten out of a single 044 on gas or E85.
I would think a single 044 could do 700. A friend of mine runs a single Walbro on his EVO with E85 and it doesn't make 700, but it runs 140mph in a full street car so I imagine it is 625-650hp. He does run it pretty lean, but it loves it. He has run it like that on the stock motor for a long time and just switched to 2 Walbros because he went to a bigger turbo.
Cyber ITR
Sep 18, 2003 10:04 AM
