ID 1000s on E85 question.
Old Apr 6, 2011 | 06:28 PM
boosted.si04's Avatar
Default ID 1000s on E85 question.
I have seen different people making different power on theses injectors on E85. I was looking to hit in the 550-600 whp range. I am going to be running a fully built 84mm GSR with a 6262 turbo. ID 1000's, walbro intake and bosch 044 inline. I know with this setup it will run at 100psi fuel pressure so is 550-600 whp capable? Also how many PSI will I have to run to make this power? Please let me know what you think, Thanks.
Old Apr 6, 2011 | 07:46 PM
Gunmetal_B20_Hatch's Avatar
Default Re: ID 1000s on E85 question.
We have a local guy making 620 on billet 67mm w/ E85+ID1000 @ 75psi. on a fully built K24.
Old Apr 6, 2011 | 08:03 PM
What was the duty cycle at do you know?
Old Apr 6, 2011 | 08:14 PM
IDK, but id expect it to be pretty high.
Forgot to add, hes got dual Walbros in-tank.
Old Apr 6, 2011 | 09:13 PM
Yeah. How many psi that take do you know?
Old Apr 7, 2011 | 04:51 AM
IHaveTurbos's Avatar
A 82mm GSR I built with the same exact fuel setup at 80psi base and with a GT35R .63a/r we stopped on 95% DC and the car made 626whp @ 21psi. The amount of PSI is going to be different from car to car as there are way too many variables that effect what a cars makes power wise and with how much.
Old Apr 7, 2011 | 04:53 AM
D-Rob's Avatar
Most cars that come through here with that fuel setup make 600-625whp on E85, at 95-100% IDC.
Old Apr 7, 2011 | 06:09 AM
Wow nice. So no reason my goal is doable. Last question I have the 2.5 motoral map sensor that will hold up to 23 psi or should I just get the hondata 4 bar map sensor?
Old Apr 7, 2011 | 07:00 AM
boosted_b16a2's Avatar
get the 4bar to be in the safe side. on my b16 81.5mm i was at 90psi with the same fuel setup and i was at 100% idc at 600hp. so yes depends on your tuner and your displacement. but you will hit your power goal.
Old Apr 7, 2011 | 07:01 AM
4cylfiend's Avatar
I like this thread. Im running a fully built 84mm gsr with a 6262 and ID1000's on e85 as well. I was wondering what kind of power i was going to be able to hit.. Im running a Aeromotive A1000 pump also.
I would upgrade map sensors to be safe.. theoretically u should be good to 29.6lbs..
Old Apr 7, 2011 | 08:29 AM
Yeah I just order the hondata one to be one the safe side. Thanks for all the input I feel much better now! Getting a new topmount, then putting the Bosch pump in, then back to the dyno.
Old Apr 7, 2011 | 09:23 AM
Muckman's Avatar
Moderator in Chief
Im making 505hp on ID1000s, E85 and dual walbros with 50psi static fuel pressure. I think my duty was 85-90%. I hope I can push 550hp out of the system this summer with more fuel pressure.
blackdude
Oct 2, 2009 11:00 AM
Boostinb20!
Feb 16, 2009 01:37 PM
Willie
Sep 11, 2005 03:05 PM
spaghizzle
Apr 30, 2003 05:14 PM
ic108
Dec 8, 2001 07:30 PM
